Back-Up Sump Pump Help
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by amsdad, May 14, 2005.
  1. amsdad
    amsdad New Member
    May 14, 2005
    Ever since our basement flooded - for the second time - I installed a back-up sump pump. However, since owning one, I've been unimpressed. I'm looking for advice in a couple areas:
    1. The current brand seems to go through 12 volt batteries quickly. Even when I add water to the battery every 3-6 months, it doesn't seem to maintain a long lifetime of use. It's usually dead before the guarantee period expires. What's up with that?
    2. Secondly, when I tested the back-up this spring, it didn't work. Even after I replaced the battery. So, I plan to replace it. What Brands to you recommend for a Back-up sump pump???
    3. Any other advice for purchasing this back-up sump pump?
    Thanks!!! ;)
  2. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    read my lips
    here is my web page to read and a link to the best unit you can buy
    this is 100% right down your alley , with the troubles you are having.
    http://www.weilhammerplumbing.com
  4. amsdad
    amsdad New Member
    May 14, 2005
    Sump Pump
    The unit on your website does look perfect for my needs. Unfortunately, no dealer in my area. I'll contact the company and see what they can do.
    Thanks - good advice. And, good website too!
Similar Threads: Back-Up Sump
Pumps and Tanks Well Forum & Blog. Water is life. Back-up Battery Sump Pump --> Can you use two batteries? Dec 2, 2011
Pumps and Tanks Well Forum & Blog. Water is life. Water-powered back-up sump pump ? Mar 13, 2010
Pumps and Tanks Well Forum & Blog. Water is life. Back-Up Sump Pump Nov 16, 2009
Pumps and Tanks Well Forum & Blog. Water is life. Back-up Sump Pump won't stop running Sep 13, 2008
Pumps and Tanks Well Forum & Blog. Water is life. Back-Up Sump Pump Which is better Aug 18, 2007
