Fidodie
Here is one that is perplexing me a bit. I am moving a full bath and laundry room to prepare for a kitchen expansion - the Laundry room will share a wall with the bath, and will have kitchen height cabinets w/drop in sink - this sink will be back-to-back with the lav.
if i use a back-to-back fitting (double combo y ? I saw it in another thread) then the flood rim of the bath sink is below the rim of the laundry sink by 4". a clog at the first bend would cause a flood in the bathroom from the laundry sink running. (I'm not sure why this bothers me so much, since a clog a bit further downstream would show up in the shower....but that would be in a 3" pipe.)
Questions:
Is this a problem (code wise - of course it is a problem is there is a clog )?
what is the correct size of the pipe (drain/vent)?
Does the double fitting orient so it fits inside the wall(2x4), then turned out with 90s?
I've refered to this forum quite a bit in the past, so it was time to join. thanks for all the help, and for checking in with this one. I'll get some project pictures up soon - I'm sure there will be more questions.
Thnx,
Pat
Oh, I'm in NJ, my inspector said to comply with the 2000 Nat Std Plumbing code as adopted NJAC 5:23-3:15 - He is available if i have questions, but i'd rather have a knowledgable discussion with him, rather than 20 questions.
Questions:
Thnx,
Pat
