Back boiler & oil boiler to twin copper cylinder
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by sheen, Dec 6, 2006.
  1. sheen
    sheen New Member
    Dec 6, 2006
    Hi,
    A friend of mine wants to to join a back boiler and an oil boiler to a twin coil copper cylinder and wants both of them to work a central heating system. Can anyone give me any ideas how best to do this.
    Thanks
  2. got_nailed
    got_nailed DIY Senior Member
    Jan 11, 2006
    Let me get this right you have 2 boilers and they want to use one or the other at different times.
    If there both closed systems you just need to put in 2 check valves and use 2 pumps. This would be coming off the hot side of the boilers. The return would go to witch ever one was sucking the water. This would work the same on a open loop system.
    You could use Water to Water Plate Heat Exchanger. But that would also be fun to describe. But it would not be too hard to draw out. The heat exchanger IMOP is not the way to go.
  4. sheen
    sheen New Member
    Dec 6, 2006
    Thanks for the info. i will pass it on to him in a couple of days, and if he needs to know more, I will add another thread.
    Sheen
Similar Threads: boiler boiler
Plumbing Forum, Professional & DIY Advice Code for wall hung boiler in bedroom Friday at 9:56 AM
Plumbing Forum, Professional & DIY Advice Internal Pipe Corrosion near boiler fill valve. Feb 3, 2017
Plumbing Forum, Professional & DIY Advice Boiler shutting off... water pressure? Feb 2, 2017
Plumbing Forum, Professional & DIY Advice Geyser question(boiler) Feb 1, 2017
Plumbing Forum, Professional & DIY Advice Boiler pressure 3 story house Dec 31, 2016
