Avoided a near disaster - Is there a solution so it doesn't happen again?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by greggor36, Jul 18, 2012.
  1. greggor36
    greggor36 Member
    Jul 18, 2012
    PA
    I recently had a supply hose to my toilet break. Luckily I was home at the time and stopped it before any damage occurred. I replaced the supply hose with a plastic fitting but am thinking of switching to a metal fitting supply hose instead. Is it worth it?
    Also, and most importantly...does anyone know anything about an auto water shutoff system? One where the system shuts the main water off when there's a water leak?
    I am interested in all feedback, suggestions and help!
    Thank you!
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Let me answer you questions in reverse. There is a supply hose that is supposed to do what you are looking for. Problem is, they tend to shut off when they shouldn't. Avoid these. Many of us like the supply hoses that have the stainless steel mesh over them. Probably the safest connection is the old fashioned solid pipe that is fit to your toilet and supply valve. These are not really a DIY friendly connection because bending the tubing to fit requires experience to avoid kinking the tubing. Just a passing thought, do you know what your water pressure is? If it is too high, that could lead to premature failure of a flexible hose. High pressure is also hard on shut off valves in toilets, clothes washer, and dishwashers. Might be worth checking.
Similar Threads: Avoided near
Plumbing Forum, Professional & DIY Advice Linear drains without a traditional liner. Yesterday at 4:09 PM
Plumbing Forum, Professional & DIY Advice Internal Pipe Corrosion near boiler fill valve. Feb 3, 2017
Plumbing Forum, Professional & DIY Advice No drain near water softener Dec 27, 2016
Plumbing Forum, Professional & DIY Advice Aesthetics: exposed heat pipe near basement ceiling Nov 28, 2016
Plumbing Forum, Professional & DIY Advice Water leaking from the bathtub near the faucet Jul 27, 2016
