Autotrol Performa Valve with a 460i control
Discussion in 'Water Softener Forum, problems, installation and r' started by jacktorgerson, Nov 11, 2012.
  1. jacktorgerson
    jacktorgerson New Member
    Nov 11, 2012
    Phoenix, AZ
    I have an Autotrol Performa Valve with a 460i control. It has stopped auto regeneration. I can manually regenerate. Any idea where the problem is?
  2. Akpsdvan
    Akpsdvan In the Trades
    Dec 29, 2009
    Business owner/service and sales
    Alaska
    Is there a little light flashing when water is used in the house?
    Could be that either the meter cable at the turbine is out of the hole or the turbine is not spinning.
    Make sure that the light is flashing when water is running.
  4. jacktorgerson
    Nov 11, 2012
    Phoenix, AZ
    Thanks,
    I checked for the flashing light when water is running in the house and it does flash when water is running.
  5. jacktorgerson
    Nov 11, 2012
    Phoenix, AZ
    I checked for the flashing light when water is running in the house and it does flash when water is running. Are there any other things to try?
  6. Gary Slusser
    Retired
    If the programming hasn't changed or you haven't changed it, I'd suspect the circuit board since the turbine is spinning with water flow and the light is blinking.
  7. jacktorgerson
    Nov 11, 2012
    Phoenix, AZ
    Thanks. Any suggestions where to look for a board?
  8. ditttohead
    Jan 9, 2012
    Ontario California
  9. Gary Slusser
    Retired
    Any local or internet dealer, some big box stores and plumbing/pump supply houses, a few plumbers or well drillers
  10. jacktorgerson
    Nov 11, 2012
    Phoenix, AZ
    360i
    WOW! looks like I can get one just about anywhere. Thanks for all your help.
Similar Threads: Autotrol Performa
Water Softener Forum, problems, installation and r Autotrol valve advice needed Apr 14, 2016
Water Softener Forum, problems, installation and r Autotrol 740 timer 7-day mode Mar 24, 2016
Water Softener Forum, problems, installation and r Is Autotrol both a valve and a water-softener unit? Jul 27, 2015
Water Softener Forum, problems, installation and r Autotrol 460i Nov 12, 2014
Water Softener Forum, problems, installation and r New home to me - Problems with Autotrol softener - salty water Oct 14, 2014
