Automatic Air Vent leaking water!
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by The Mountain Goat, Feb 9, 2005.
  1. The Mountain Goat
    The Mountain Goat New Member
    Feb 9, 2005
    First, this is a great forum. Thanks to all in the community.
    I have a well tank that runs through an air tank then through an iron filter, through a water softener, and then through the house. Atop the air tank is a Braukmann EA122 Automatic Air Vent. I used to get a sucking sound at the top of the vent. Now I have water dribbling out the top. I also have about 20 lbs on the pressure gauge.
    Any ideas as to what I should check?
    Here's a photo of the leaking system www.wjw.org/30 046.jpg
    Here's a photo of the EA122 air vent www.wjw.org/30 047.jpg
    I appreciate any suggestions. Thanks.
  2. jadnashua
    If I understand how those tanks and valves work, it sounds like your valve is not sealing properly and letting the air out. IF I've got this right, it will cause the pump to short cycle. Don't know if the valve is separately replaceable, but if it is, suggest replacing it. The high pressure limit should cause the pump to shut off before water reaches the height in the tank of the valve. If the air is leaking out, then it will fill up with water, rapidly max out the pressure, and shut the pump off. Normally, the pressure would gradulally increase as it compresses the trapped air. If yours spikes, that would be consistent with my understanding. Note, I'm not a pro.
  4. The Mountain Goat
    Feb 9, 2005
    More on the air vent...
    Thanks Jim. The vent can be replaced. I noticed in the photo that it can be twisted to turn it on or off. When I did the entire unit including the brass base moved, so I'm certain it is loose.
    One more question before I attempt to remove it. Do I have to concern myself with air pressure in the tank? The pressure gauge goes up to 50 when I turn the water off.
    Thanks.
    From another Jim.
  5. jadnashua
    You need one of the pros to verify my thoughts before you tear anything apart and start changing things. I think I understand your problem, but I'm not certain.
  6. The Mountain Goat
    Feb 9, 2005
    Problem solved!
    For all those who like a happy ending...
    I tightened the air vent to the tank, and then uscrewed the top of the valve. Inside is a float with a mini surfboard. The float is supposed to push the mini-surfboard up against the rubber seat on the bottom of the air valve, keeping water from the vent. Its almost like a one barrel carburator with float, needle and seat.
    Anyway, since the air tank is inline before the iron filter, I had iron sediment coating the surfboard and the rubber gasket, keeping it from sealing. I cleaned everything up, reassembled, and now the leaks are gone, and the water pressure and volume are much greater.
Similar Threads: Automatic Vent
Pumps and Tanks Well Forum & Blog. Water is life. How can I automatically take water from 2 underground water tanks Jun 29, 2014
Pumps and Tanks Well Forum & Blog. Water is life. Automatic water valve fitting Jun 29, 2014
Pumps and Tanks Well Forum & Blog. Water is life. Grundfos Constant Pressure System - Constantly Pumping, won't turn off automatically May 22, 2011
Pumps and Tanks Well Forum & Blog. Water is life. Square D Control Switch with Automatic Low Pressure Cut Off Feb 12, 2010
Pumps and Tanks Well Forum & Blog. Water is life. Well Pump won't engage or switch off automatically Oct 27, 2008
