Auto drain valve
Discussion in 'Irrigation / Sprinkler Forum' started by rockycmt, May 7, 2008.
  1. rockycmt
    rockycmt Member
    Nov 13, 2007
    New York Metro Area
    While rebuilding my system I noticed they had installed auto drain valves at the lowest point. Since I had the line dug up I decided to remove it incase it was faulty since it was old. How do these things work? Do they sense low pressure and open? Are these reliable? If I do not reinstall it will I be ok with just blowing my lines with air before the winter?
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Interesting question! I installed my sprinkler system in 1985 and, following directions of the designer, I installed several automatic drains. It wasn't until that fall that it occurred to me that I had no way of know if they were working. Now, I had socked the lines 2 feet deep, but sometimes it does get cold enough to freeze that deep, so I started having my system blown out. I do it myself now, but I still don't know if the automatics are working or not. Since I have my own air compressor, blowing the lines is not a big deal or expense, but if I had to hire it done it would probably cost $50 or more every year. Guess my compressor has paid it way pretty well.
  4. jimbo
    jimbo Plumber
    San Diego, CA
    Auto drain valves are "normally open" to atmosphere. When pressure is applied in the system, they close to allow the system to operate, and are spring loaded back to "open" when pressure is removed.
    On the submarine, we had to know where all the auto drain valves for main ballast tank blow system were. They were located very low in the boat...usually right near deck plate level in the lowest level. They made sure that no condenstation was allowed to accumulate in the line, but had to close in a hurry when the 4500 PSI air hit them. You had to observe the valves on a regular...hourly....basis, because they acted as a "tattle tale" in case the MBT blow hull stops leaked by...( water in the people tank...not good!)
Similar Threads: Auto drain
Irrigation / Sprinkler Forum Automatic line drains Jun 24, 2010
Irrigation / Sprinkler Forum Thoughts on auto-drains May 31, 2007
Irrigation / Sprinkler Forum Yard hydrant/automatic horse waterer question Sep 5, 2016
Irrigation / Sprinkler Forum automated irrigation system Sep 20, 2013
Irrigation / Sprinkler Forum automatic sprinkler valves May 1, 2013
