Attach faucet directly to granite counter?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by chrisd, Mar 9, 2006.
  1. chrisd
    chrisd New Member
    Mar 9, 2006
    I have what I'm sure is a basic question, but I haven't been able to find a reference in previous posts.
    My single-hole faucet has become loose underneath my granite counter. Apparently, water has been getting in through the hole the past year and has left the wood underneath (plywood?) rotted and nasty and probably contracted.
    When I mentioned it to a friend that was over, he suggested drilling a hole into the wood about a half inch larger than the faucet. He said that attaching the faucet to the granite was the way to go and that the guy who installed it was probably lazy.
    So are all properly-installed faucets tightened directly to the granite? Are there any things I should watch out for, like over-tightening?
    Thanks.
  2. Terry
    Aug 17, 2004
    I prefer mounting the faucets to granite, and not to the wood.
    Wood compresses.
    It would be nice, if whoever is cutting the faucet holes in the granite, also precut the wood a bit bigger for the plumber.
    It's hard to tell someone how tight to put things.
    It's a feel thing.
  4. jimbo
    jimbo Plumber
    San Diego, CA
    This is a very common "trouble" area. For some reason, the kitchen design contractor and the granite people like to keep their head in the sand, or some where else I won't mention, and bring in someone at the last minute to install a faucet and have not given any previous consideration to the install issues such as you mentioned.
    The even worse situation is the homeowner who is buying fixtures on his own. He spends a fortune on a nice marble or granite kitchen or lav. Then goes to HD the night before he has someone coming in to install the faucet. He buys one off the shelf, not realizing that he really needed to order a long shank model, with 4 weeks lead time. Then doesn't understand why the plumber can't install his little beauty!
  5. Terry
    Aug 17, 2004
    Jimbo is right,
    You can get the long shank models, or even extensions for some faucets.
    Most extensions arrive in a few days.
    But yes, it's another trip for the plumber, and time for the phone call as well.
    Did I say "TIME"?
    It all adds up.
  6. sulconst2
    sulconst2 New Member
    Jul 11, 2005
    remodeler
    old bridge nj
    wondering why there would be plywood under granite. if this is a kitchen then the granite should have been installed directly on the cabinets. if you have a blind corner then bracing is used to support the counter. unless this is granite tile?
  7. jadnashua
    It could be 2mm slab or tile...then you might want/need plywood underneath.
  8. chrisd
    chrisd New Member
    Mar 9, 2006
    Thanks Terry for the advice - I will drill a hole then into the wood.
    On a related note, I've narrowed my choice of a new kitchen faucet down to Grohe and Hansgrohe.
    I'm aware of Grohe's sterling reputation, but just how much better - in dollars - is Grohe compared to Hansgrohe. For example, if I'm spending $200 for a Hansgrohe, is a Grohe worth another $100? $200?
    Also, I'm strongly considering buying a faucet off E-b a y. But because the warranties for both companies require a receipt, I don't think I'll be eligible to use it if the need ever comes up. Does anyone have any knowledge regarding the frequency of repair for either brand and the likelihood I'll have to use a warranty in the future?
    Thank you for your help.
  9. chrisd
    chrisd New Member
    Mar 9, 2006
    Not sure of the thickness, but I just thought plywood was needed for a level surface and additional support . Wish I knew better, but kinda clueless when it comes to this stuff.
  10. Terry
    Aug 17, 2004
    Most of the stone I see is laid on plywood.
  11. toolaholic
    toolaholic General Contractor Carpenter
    Jul 16, 2005
    Repairing and remodeling homes
    Marin Co. Ca.
    I See More Trouble
    The existing hole gives you no pilot for a hole saw to stay centered on!
    a plywood temp needs to be used to stay centered in the existing hole.
    hope you have the skill to do a clean job. good luck
  12. chrisd
    chrisd New Member
    Mar 9, 2006
    toolaholic,
    You mean I should place another piece of plywood under or over the hole to create a pilot hole?
  13. toolaholic
    Jul 16, 2005
    Marin Co. Ca.
    Yes
    you can't secure from the finished top with screws,so underneath is your option, CAREFULLY ,using a narrow peice of plywood,screw it in place through the existing ply. a couple of inches past each side. frim above . carefully drill an 1/8" center hole in the ply. now using a hole saw drill an over size holethrough the template and under counter ply. not easy access
    good luck tool
  14. chrisd
    chrisd New Member
    Mar 9, 2006
    Thanks for the advice Toolaholic...will put it to good use.
  15. hj
    hole
    You use one hole saw the size of the existing hole and then fasten it to the saw's mandrel, as a guide, inside the one for the new hole. The mandrel will have the instructions how to do it.
  16. chrisd
    chrisd New Member
    Mar 9, 2006
    I don't understand this statement - I put the smaller saw inside the larger one, or the hole? Could you clarify please?
    And anyone with an opinion in regards to Grohe faucets and frequency of repairs?
  17. toolaholic
    Jul 16, 2005
    Marin Co. Ca.
    HJ,HOW does the double cutters attach to the mandrel?
    I MUST HAVE 5 morse ones with a male thread and pin lock. vagely ,i seem to remember seeing this somewhere. the inside cutter would have to be longer to pilot ,i believe.
    on GROHE faucets , i believe the problems of slow flow come from the 2 filters on the feed ends blocking from minute debrea . i also had a friend ask me about reduced flow on theirs. Am a carpenter plumber ,and don't have the experiance of many knowegeable folks here.
    Thank's in advance for answers Tool :)
  18. chrisd
    chrisd New Member
    Mar 9, 2006
    Is there a known problem with slow flow on Grohe faucets?
  19. ToolsRMe
    ToolsRMe New Member
    Mar 12, 2006
    CO
    Ooooo ... I love that solution!
    I could have used it yesterday as well as a week ago. Sigh.
  20. jadnashua
    Almost all faucets have screens on their inputs to block crud from getting to their insides. The crud, rust, sand, or who knows what, can ruin the cartridge. To prevent that from happening, they use the coarse filter screens on the input. You shouldn't have any stuff large enough to clog the screens running in your pipes, but if you do, it is better to block it so you don't ruin the cartridge. The screens can be cleaned...for free except for a little time, if and when it happens. The cartridge is not cheap, but may not be exorbitantly expensive, either depending on the brand. So, if the flow gets slow, clean the screens. Then figure out why they are getting clogged so it doesn't happen again.
    You car won't run if the fuel filter gets clogged either...should you remove the filter to try to get another few miles out of it as the injectors get clogged one by one?
Similar Threads: Attach faucet
Plumbing Forum, Professional & DIY Advice Leaking outdoor faucet attached to house Jan 6, 2017
Plumbing Forum, Professional & DIY Advice Attaching faucet supplies to Premier Kitchen faucet Apr 3, 2012
Plumbing Forum, Professional & DIY Advice Faucets with attached supply lines Dec 25, 2011
Plumbing Forum, Professional & DIY Advice Attach 1/2" Copper Pipe to a 1-1/4" Union on a Brass Pump Tuesday at 4:48 PM
Plumbing Forum, Professional & DIY Advice How do I Extend Existing Waste Pipe In Order to Attach Toilet Flange Mar 4, 2017
