AS Cadet PRO - better or worse?
Discussion in 'Toilet Forum discussions' started by Hillel, Jul 23, 2012.
  1. Terry
    Aug 17, 2004
    Your neighbor has good taste.
  2. Cameron Fields
    Cameron Fields Implementer/Inventor
    Mar 5, 2013
    2 year lawn , Theorist, Designer/inventor,Animator
    Florida
    Well maybe I've been single minded, do you happened to know how well reverse flush toilets work?
    and if they are easy to install I need to install one in a basement up north in Carolina.
  3. Terry
    Aug 17, 2004
    Yuck!
    So you poop on a shelf, and then get to smell it.
    Wonderful!
    You don't think pooping on dry porcelain is going to be a problem?
    Big type just like Master Plumber Mark would have done. Dooh!
  4. Terry
    Aug 17, 2004
    [​IMG]
    A very marginal American Standard Evolution Cadet, Marginal at best is what the homeowner said.
    Not at bad as her Glacier Bay toilet which she had tried to return.
  5. Terry
    Aug 17, 2004
    [​IMG]
    American Standard Cadet 3 elongated bowl with a built in lean.
    This came from a home center.
    I've tried to install bowls that customers have picked up on their own. I remember on A/S Antiquity that was so warped on bottom that it would have taken 1/2" shims at the back.
    I've seen Cadet 3's at a home center that was a little like a rocking horse, it was high centered in the middle.
    When I go out to install, I don't like surprises when I pull them from the box. Like the round bowl in the elongated box I pulled out one time.
    Crazy.
  6. jadnashua
    One apartment I had in Germany used that type of toilet...I did not like it at all. And, better close the cover before you flush, or you'll spray the room. Plus, you better have a big water line as it's similar to a flushometer - it needs a big line (at least on the ones I've seen).
  7. wptski
    wptski Retired Machine Repairman
    Oct 20, 2012
    Warren, MI
    In all fairness, you should also show a level on the floor as well. My Cadet 3 from HD wasn't that far off but I had to shim because of the floor. The exit trapway surface was higher than the outside edge of the bowl, so it would rock on its center when on the floor.
  8. Terry
    Aug 17, 2004
    The person that posted that picture had put the level on the floor. The floor was level.
    But again, I do think that the Pro versions of the Cadet "are" better then the homeowner versions.
  9. wjcandee
    wjcandee Wise One
    Apr 27, 2012
    New York, NY
    Huh. Personal experience with the original Drake, the Carlyle (like an Ultramax II with a skirt), and the Aquia.
    After the stupid Consumer Reports article that accused a Toto of not disposing of the liquid fully, I have actually tested all three of these models with richly-colored fluid. It all disappears and leaves no color in the refilled bowl. All are properly-installed, however, and that may make a difference.
  10. Terry
    Aug 17, 2004
    The Ultramax II is one of my biggest sellers. It's an easy repeat sale. They buy one, they buy again.
    The video that CR did was of a plugged bowl. It wasn't an install problem, it was sabotage. At least it would be if they knew what they were doing with toilets in the first place.
    I like this video that TOTO did better
    [video=youtube;Xn9_zctMge0]http://www.youtube.com/watch?v=Xn9_zctMge0[/video]
  11. Cameron Fields
    Mar 5, 2013
    Florida
    No that's forward flush I reverse flush or up flush toilets that use the reverse impeller function. like this
    sorry for the confusion not those other german toilets yuck
  12. Cameron Fields
    Mar 5, 2013
    Florida
    DEFEAT Toto has won there is evidence clearly "Lord help me when my toilet design goes into production"
  13. Terry
    Aug 17, 2004
    Back outlet bowls historically have had issues flushing.
    Most still on the market in the US are pressure assist bowls. When I've asked manufacturers about this, they noted that it can take a lot to flush that direction. Most wall hung bowls now use a Flushometer in commercial use. Gerber has come out with a 3" Flushvalve Maxwell for their rear outlet floor mount and their wall hung. American Standard, Gerber and Kohler use pressure assist on their rear outlet bowls.
    Gerberit does make a wall hung set up. I used some like that in Amsterdam and India.
  14. Cameron Fields
    Mar 5, 2013
    Florida
    oh ok thanks.
  15. kshorty
    kshorty New Member
    Apr 6, 2013
    Brooklyn, NY
    That's good to know. Thanks.
  16. kshorty
    kshorty New Member
    Apr 6, 2013
    Brooklyn, NY
    By the way -- if you see this, gusherb94 -- I saw your video online of the Cadet Pro flush. It seems like it took a longish time for it to refill. Would that be because of the rigging set-up, or is that how it is? Thanks for your help.
  17. GoKohlerGo
    GoKohlerGo Brand New Plumber
    Aug 11, 2012
    Michigan
    Plugged bowl? I don't think so. If it was plugged, how would the water go down? Why would you think it was sabotage? They are Consumer Reports. Not Conscammer Reports.
  18. jadnashua
    When there's something caught in the trapway, it is fairly common for liquids to leave, but solids to butt up and into that obstruction. Something like a pen, pencil, crayon, small toy, whatever can do that. The siphon jet on a Toto moves things quite fast...any time you see it delayed, there's something wrong. In 12-years, I've not needed a plunger...the old ones, a couple of times a month. To me, anyway, that says something. ANd, it's doing this on less than half the water of the old ones.
  19. GoKohlerGo
    Aug 11, 2012
    Michigan
    Can you tell me why they would purposely put something in the trapway?
  20. Terry
    Aug 17, 2004
    At nineteen years of age, you haven't seen much yet.
    It's very common for kids to put things down a toilet and watch it go. Wait till you get older and have kids of your own.
    Plenty of things drop into bowls. I once found a ball that the family dog had dropped in. It was found stuck at the bottom of the bowl outlet. Nothing solid was going to get past that. After the flush, it would float up a bit and slowly let liquid out.
    Cell phones, bars of soap, pens, small cars, action figures,
