Are the trap arms 2inch or 1 1/2 inch?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by GeronimoDF, Jul 23, 2010.
  1. GeronimoDF
    GeronimoDF New Member
    Oct 5, 2009
    Long Island, NY
    Hi,
    Just bought a double fixture fitting, but the side pieces are 1 1/2 inches. In this picture, are they 1.5 or 2 inches? Would it be a problem using 1.5 inches for the trap arms?
    [​IMG]
    Thanks again,
    Dan
  2. nhmaster3015
    nhmaster3015 Master Plumber
    Jul 30, 2008
    Teacher
    The granite state
    What picture?
  4. Doherty Plumbing
    Doherty Plumbing Journeyman & Gas Fitter
    Jun 22, 2009
    Red Seal Journeyman Plumber & Licensed Gas Fitter
    Penticton, BC
    Looks like 1.5" to me because the trap arms look slightly smaller then the 2" branch.
    1.5" for a lav like that is perfectly fine. You'll probably find that code says 1.25" is adequete.
    Look on the 90* eblows. It should say on there what size they are.
  5. nhmaster3015
    Jul 30, 2008
    Teacher
    The granite state
    It's a 2 x 1.5 x 1.5 x 1.5 san tee and thank god I will never have to snake that one :)
  6. asktom
    asktom Member
    Nov 9, 2009
    Victor, MT
    That is a double fixture tee and the 1 1/2" arms are fine. I don't much like the 1/4 bends below it without a cleanout, however. (A UPC oriented opinion)
  7. hj
    The arms and the vent are 1 1/2" which is almost standard for a lavatory. IF the arms had to be longer, then a 2x1 1/2x2x2 fixture fitting might be used. Even with the "sweeps", good plumbing practice dictates that cleanout be installed in the vertical pipe, unless it is dropping directly into the main line. In the picture, IF I had to offset the fitting, I would have used 45's to make a "slight" jog and installed the fitting to the left closer to that sink than the right hand one.
Similar Threads: trap arms
Plumbing Forum, Professional & DIY Advice Can you join 2 p-trap arms (horizontally) before the vent? Jan 24, 2012
Plumbing Forum, Professional & DIY Advice WASHER DRAIN TO KITCHEN SINK TRAP Feb 12, 2017
Plumbing Forum, Professional & DIY Advice P trap question... Feb 9, 2017
Plumbing Forum, Professional & DIY Advice Leaky trap Feb 6, 2017
Plumbing Forum, Professional & DIY Advice 45's to trap Feb 6, 2017
