Are Sharkbite and other quick connect fittings reliable?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by amateurplumber1, Jul 18, 2013.
  1. amateurplumber1
    amateurplumber1 Member
    Mar 10, 2013
    Here
    deleted
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    I would use any of them. As far as restricting flow, I doubt it. Reliable? Maybe. Haven't heard of any blowing out. What's the matter with the tried and true sweat joints?
  4. amateurplumber1
    Mar 10, 2013
    Here
    deleted
  5. craigpump
    craigpump Well-Known Member
    Apr 12, 2012
    Self employed water system tech
    Yeah they are reliable, I haven't seen one fail yet. Matter of fact, I saw a submersible pump hung on Pex and Shark Bites a few years ago.
  6. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    They are crap. I've seen a lot of them leak.
  7. Gary Swart
    Sep 1, 2004
    Yakima WA
    If you want to DIY projects around the home, you just have to have some basic tools and be able to use them. Doesn't mean you have to be a journeyman that has every tool you'd ever need, doesn't mean you have to know all about every facet of every job, but you can't do quality work with plug together handyman junk that fill the shelves in discount stores. If you are going to work with plumbing, a propane torch, flux, solder, and a pipe/fitting cleaning tool doesn't cosst an arm and leg. Sweating copper is not rocket science (but yes, it does have to be done correctly) and can be learned with a few pieces sacrificial pieces of pipe and fittings. If you don't feel up to this, then hire a plumber.
  8. DougB
    DougB Member
    Jun 19, 2010
    Software Developer / Engineer
    Minneapolis - Land of 10,000 taxes
    With enough money - anyone can get anything 'waviered'. That is 'approved' - even though it is crap. As a degreed engineer I can tell you that you need a mechanical joint between two components.
    Whether it's a weld, silver solder, solder, crushed, or threaded you need one of those. To assume that you can get a friction fit with an O-ring gasket is folly.
    Soldering technique is easily learned. If you don't want to try - then get a pro to fix it.
  9. jadnashua
    I wonder how many people actually use their deburring tool and follow the instructions. It's not hard to nick or slice an o-ring. Much less chance of that happening if the end is properly prepared. Only take a moment.
Similar Threads: Sharkbite quick
Plumbing Forum, Professional & DIY Advice Sharkbite leak on PEX Dec 5, 2016
Plumbing Forum, Professional & DIY Advice Sharkbite Nov 11, 2016
Plumbing Forum, Professional & DIY Advice Sharkbite vs EPC or Mueller Jun 23, 2016
Plumbing Forum, Professional & DIY Advice Warning!! Sharkbite fitting corroding May 17, 2016
Plumbing Forum, Professional & DIY Advice New Sharkbite 3/4" ball valve leaks Feb 14, 2016
