Are all pex crimpers the same?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by spresco, Jan 29, 2007.
  1. spresco
    spresco New Member
    Jan 28, 2007
    I have compared crimp rings and fittings for both Vanguard and Zurn. The Vanguard crimp rings are a little wider and a bit thicker than Zurns rings. The fittings look to be the same. Can you use a Zurn crimper on a Vanguard crimp ring as long as you use a Vanguard go/no go gage? The Vanguard crimpers are more expensive.
  2. dubldare
    dubldare Plumber/Gasfitter
    Sep 14, 2005
    Plumber/Gasfitter
    MN/ND
    Check the ASTM numbers on the fittings, piping and the rings. Same numbers- same tool.
  4. RRW
    RRW New Member
    Jul 15, 2005
    Illinois
    My daughter just loaned me a copy of the "household handyman" and there is a pretty extensive article on PEX. I noticed that they stated that different manufacturers have different crimp tools which are not interchangeable. You might want to check it out. Good Luck
Similar Threads: crimpers same
Plumbing Forum, Professional & DIY Advice Pex crimpers Dec 10, 2010
Plumbing Forum, Professional & DIY Advice crimpers Jan 24, 2008
Plumbing Forum, Professional & DIY Advice Washer drain same as sink ? Jan 27, 2017
Plumbing Forum, Professional & DIY Advice Same lady from ballcock with yet another question.... Nov 30, 2016
Plumbing Forum, Professional & DIY Advice What causes 3 separate leaks to occur at the same time? Aug 28, 2016
