arc fault tripping
Discussion in 'Electrical Forum discussion & Blog' started by toolaholic, Aug 19, 2010.
  1. toolaholic
    toolaholic General Contractor Carpenter
    Jul 16, 2005
    Repairing and remodeling homes
    Marin Co. Ca.
    New work, bedroom low voltage halogen bulbs 4 fixtures with transformers. they trip 15 amp breaker.
    Wired properly. No I didn.t run nuetral to ground. Any ideas appreciated thanks tool
  2. jadnashua
    Double-check all connections to verify they are tight. Are the low-voltage ps passive or active devices (i.e., heavy transformers, or electronic devices)? Disconnect one fixture/transformer at a time and see if that helps isolate the problem. You could also have a nail or staple in a wire somewhere. Does it trip immediately, or intermittently after some arbitrary delay? Not all arc detecting cb are created equal...some have better filters in them to prevent nuisance tripping.
  4. toolaholic
    Jul 16, 2005
    Marin Co. Ca.
    will check thanks
  5. toolaholic
    Jul 16, 2005
    Marin Co. Ca.
    Here's what is strange. these two bedrooms had new incandescent light fixtures earlier, no tripping then. As soon as we switched to low voltage with transformers,both rooms[ 2 seperate arc fault circuits]
    started the occasional false tripping . We are licensed for this and did a new 200 amp service,all new wiring signed off. We all are the Manuf. Guenne pigs for these arc faults,i feel
Similar Threads: fault tripping
Electrical Forum discussion & Blog Two pole arc fault breakers for multi wire circuits Jan 6, 2014
Electrical Forum discussion & Blog Bad breaker or ground fault? Mar 20, 2013
Electrical Forum discussion & Blog Faulty breaker? Mar 19, 2011
Electrical Forum discussion & Blog using coleman ground fault extention cord with portable generator Feb 24, 2011
Electrical Forum discussion & Blog HELP with installing Fault Interrupter Electrical Outlet!!!! Jun 14, 2010
