Arc fault circuit breakers
Discussion in 'Electrical Forum discussion & Blog' started by chukakid, Mar 30, 2009.
  1. chukakid
    chukakid New Member
    Jan 27, 2009
    retired
    colorado
    Finishing a basement and local jurisdiction has adopted 2008 NEC code but I'm still having trouble understanding which circuits require the ARC fault. I'm laying out 15AMP lighting circuits and 20AMP outlet circuits. The Bath and the wet bar area will have 20Amp GFI outlets. The basement will have a bedroom, exercise room, entertainment room, wet bar area and game room. I think I need the ARC breakers for each room except for the GFI circuits, is that correct? :confused:
  2. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    Everything down there will need AFCI
    (B) Dwelling Units. All 120-volt, single phase, 15- and 20-ampere branch circuits supplying outlets installed in dwelling unit family rooms, dining rooms, living rooms, parlors, libraries, dens, bedrooms, sunrooms, recreation rooms, closets, hallways, or similar rooms or areas shall be protected by a listed arc-fault circuit interrupter, combination-type, installed to provide protection of the branch circuit.
  4. drick
    drick In the Trades
    May 16, 2008
    Check that your town actually adopted that part of the code. Towns don't always adopt everything within the 2008 code even though they say they are using the 2008 code.
    -rick
  5. chukakid
    chukakid New Member
    Jan 27, 2009
    retired
    colorado
    Thanks, are there any specific brands that you would recomend? I'll be putting them in a new subpanel just for the basement circuits. I'll have single pole 15amp and 20amp breakers?
  6. Billy_Bob
    Billy_Bob In the Trades
    Apr 2, 2008
    The general idea is "wet areas" GFCI, so bathroom, kitchen, garage, outside outlets, and basement.... Then everything else AFCI.
    But you are finishing your basement... But then you will have a "wet area" (wet bar)...
    To be sure, I would ask your electrical inspector before installing this stuff.
    Dumb question: Would a "finished" basement be less wet than a non-finished basement?
  7. iminaquagmire
    iminaquagmire DIY Senior Member
    Dec 16, 2007
    FF/EMT
    What do you mean by brands? Use the brand of breakers that matches the panel you are using. You can't go wrong with Square D QO panels and breakers.
  8. franck@geneseo.net
    franck@geneseo.net New Member
    Apr 13, 2009
    Since we are on the topic of Arc-fault breakers, how many outlets can you put on one Arc-fault breaker? Compared to a standard breaker they are kind of expensive and I'd like to put two bedrooms on one breaker.
  9. jbfan74
    jbfan74 Electrical Contractor
    Jun 14, 2007
    Newnan, GA
    Follow the same rules for sizing a circuit.
    Being an arc fault, gfci, or standard breaker makes no difference when sizing a load.
  10. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    A bounty hunter like in "Raising Arizona"
    MD
Similar Threads: fault circuit
Electrical Forum discussion & Blog 15 amp arc fault receptacles on 20 amp circuits? Sep 5, 2016
Electrical Forum discussion & Blog Two pole arc fault breakers for multi wire circuits Jan 6, 2014
Electrical Forum discussion & Blog Tracing a 110v outlet circuit fault Jun 14, 2008
Electrical Forum discussion & Blog Bad breaker or ground fault? Mar 20, 2013
Electrical Forum discussion & Blog Faulty breaker? Mar 19, 2011
