Aquatstat removal from hot water heater
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Leemonster, Feb 27, 2005.
  1. Leemonster
    Leemonster New Member
    Feb 27, 2005
    I'm removing an oil-fired hot water heater and was wondering if there are any tricks to removing the aquastat without damaging anything. There only appears to be a set screw to remove. Should I expect any suprises? Thanks
  2. hj
    aquastsat
    Probably not. The set screw should release the aquastat from the well and then you can unscrew the well from the pipe. Assuming your aquastat is not a permanently assembled one that you have to unscrew the entire unit from the pipe.
Similar Threads: Aquatstat removal
Plumbing Forum, Professional & DIY Advice Faucet Handle Removal & Leak Repair Feb 8, 2017
Plumbing Forum, Professional & DIY Advice Kitchen faucet removal. Can't get nut off. Feb 2, 2017
Plumbing Forum, Professional & DIY Advice Tub-Shower Valve Stem ID/Removal/Replacement Jan 31, 2017
Plumbing Forum, Professional & DIY Advice Grohe 3/4 roman tub diverter valve broke in middle removal help Dec 11, 2016
Plumbing Forum, Professional & DIY Advice Waste arm removal from black cast iron vent pipe Dec 3, 2016
