Aquabrass Thermostatic Shower Valve Install
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by cjt, Nov 21, 2008.
  1. cjt
    cjt New Member
    Jul 13, 2006
    I purchased an Aquabrass shower system that includes the thermostatic valve/volume control. However, the instructions are quite brief...so I am seeking expert opinions.
    The valve connections for the supply lines and the outlets for the shower head and handheld shower are 1/2" female npt. I am wondering the best way to make these connections. Is it best to makeup the male 1/2" connection with teflon into the valve then solder the copper supply/outlets to these??
    BTW, here is the link to the install document: http://aquabrass.com/data/3/files/installation/PRO180849B0INST_E.pdf
    TIA
  2. hj
    valve
    NO. Solder the tubing stubs to the adapters and then screw the adapters into the faucet. More important than that, however, is knowing where, or if, repair parts will be available for that faucet in a couple of years or so.
  4. cjt
    cjt New Member
    Jul 13, 2006
    Good plan...I assume one benefit will be avoiding heating up the valve that could damage.
    Aquabrass is a fairly well known brand up here in Canada. I think it is a little higher end than the likes of the stuff at Home Depot. I am hoping parts availability will not be an issue.
  5. hj
    valve
    It is not only an advantage, it is the only reason for doing it.
Similar Threads: Aquabrass Thermostatic
Plumbing Forum, Professional & DIY Advice Fantini shower thermostatic mixing valve with 3 vol controls no cold water Mar 29, 2016
Plumbing Forum, Professional & DIY Advice Thermostatic Mix Valve at Kitchen Sink? Sep 28, 2015
Plumbing Forum, Professional & DIY Advice Bottom port on kohler thermostatic valve Sep 4, 2015
Plumbing Forum, Professional & DIY Advice Thermostatic shower valve - water hammer Jun 14, 2015
Plumbing Forum, Professional & DIY Advice Need help finding thermostatic shower valve May 14, 2015
