approved drain line material
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by BluesMan, Nov 13, 2008.
  1. BluesMan
    BluesMan New Member
    Nov 8, 2008
    So I called the local building inspector and talked to him about installing my water softener. I told him that I plan on draining the unit into the floor drain, and he is fine with that, but he said that I must have an air gap of a couple of inches, and I must use an approved material for the drain. He didn't elaborate much, and was in a hurry to get out the door to do inspections.
    I was planning on using PVC....but can poly tubing be used?
  2. 99k
    99k Radon Contractor and Water Treatment
    Aug 16, 2008
    Contractor of Radon Reduction, Testing, and Water
    Fairfield Co.,Connecticut
    Poly tubing is fine ... but do you know where that floor drain goes? Does it just dump under the slab or does it head out into the woods. I would solve that mystery before using it.
  4. BluesMan
    BluesMan New Member
    Nov 8, 2008
    The drain heads outside.....
  5. hj
    drain
    quote; The drain heads outside.....
    Don't they all? Where outside?
  6. Gary Slusser
    Retired
    I think the guys your bought the softener from should be telling you what and how to do the drain. I do.
  7. kingsotall
    kingsotall Plunger/TurdPuncher
    Aug 17, 2008
    Hand copper part cleaned ready to go
    Flagstaff, AZ Sitting on an upside down 5 gallon b
    Sounds like me when it comes to all these hydronics questions.
Similar Threads: approved drain
Plumbing Forum, Professional & DIY Advice P-trap Approved In Nyc Jul 14, 2006
Plumbing Forum, Professional & DIY Advice New P Trap drains very slowly. Tuesday at 6:39 AM
Plumbing Forum, Professional & DIY Advice Best way to remove this faucet drain? Monday at 9:32 AM
Plumbing Forum, Professional & DIY Advice Bathroom sink drain gurgles going down. Sunday at 1:49 PM
Plumbing Forum, Professional & DIY Advice Recommended rough-in height for kitchen sink drain? Sunday at 11:21 AM
