? Application of T plus 2 Rectorseal
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by handygirl911, Sep 8, 2006.
  1. handygirl911
    handygirl911 New Member
    May 1, 2006
    Irving, Texas
    I forgot to get PVC glue while at Home Depot. I have this Rectorseal T Plus 2Teflon Thread Sealant. What I am trying to do is attach a PVC cap onto a PVC pipe and a threaded adapter on the other end. I need this to have a good seal because I will be pouring Muratic Acid in the pipe to soak limed up stainless steel. My question is concerning the sealant. Is this a strong enough adhesive to seal the pipe fittings? Thank you for your advice.:)
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    I have serious doubts for this reason. So-called PVC glue is not glue or adhesive. It is a solvent that liquifies the surface of the PVC pipe and fitting for a few seconds while the joint is being assembled. It actually welds the joint together, much like metal welding where the heat liquifies the metal of both pieces being welded and allows the metal to flow together. Virtually any hardware store will have PVC solvent, and I suggest you get the proper material. Note: ABS is joined the same way except the chemical is different.
  4. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    dont be stupid
    Dont be foolish........
    go back to the store and shell out
    3 bucks for the right pvc glue....
    you are pouring muratic acid into something you are
    attempting to "half ass" together right?????
    what do you think might happen????
  5. Cass
    Cass Plumber
    Nov 12, 2005
    If the chamber you have made is air tight and you pour the acid into it and seal it it could explode from pressure build up. Why don't you get a plastic open vessel and do this outside. Thread sealant will not bond, glue, or solvent weld PVC pipe.
  6. hj
    sealant
    I guess I misread your posting. I thought you wanted to use the sealant to connect a cap to the threaded connection, not "glue" the pipe together. There is no way it would make a leakproof joint, and since it is also a lubricant, the pipes would probably come apart even easier than if you had just pushsed them together without anything on them.
Similar Threads: Application plus
Plumbing Forum, Professional & DIY Advice PVC vs copper in this application Dec 12, 2016
Plumbing Forum, Professional & DIY Advice Is this a correct application of a low-heel fitting? Dec 16, 2015
Plumbing Forum, Professional & DIY Advice Where to buy an air vent valve for a residential application? Jan 26, 2013
Plumbing Forum, Professional & DIY Advice Dielectric Union Application Apr 6, 2011
Plumbing Forum, Professional & DIY Advice second stage regulators, propane application Aug 4, 2010
