Appliances - Dry Rot?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by MB1, Apr 6, 2013.
  1. MB1
    MB1 New Member
    Apr 6, 2013
    Pennsylvania
    Hi all,
    My old Maytag washer and old dishwasher have been sitting for about 1-1/2 years unused. Is dry rot a problem on any of the rubber parts? The hoses on the washer were replaced 1-1/2 years ago but had been used a bit. Anything else to be concerned about when putting them back in service?
    Had this happen with an uninstalled used toilet that sat a long time.
    Another old toilet has been put back on, after sitting about a year uninstalled with tank attached. He replaced the flap.
    Thanks.
  2. Cameron Fields
    Cameron Fields Implementer/Inventor
    Mar 5, 2013
    2 year lawn , Theorist, Designer/inventor,Animator
    Florida
    Storage
    Well if it was stored in a shed or indoors it will most-likely still work fine. Out in the heat you are going to have a big problem especially if it has been in hot and cold temperature.
  4. MB1
    MB1 New Member
    Apr 6, 2013
    Pennsylvania
    They were previously in operation for years but have been sitting in the house, HVAC on. Both are connected, just not used for almost 1-1/2 years. Worried about any rubber parts dry rotting like a toilet had done.
    This toilet had been disconnected. The flapper was replaced at reinstall. He didn't say anything about the gasket or other parts.
  5. Cameron Fields
    Mar 5, 2013
    Florida
    You can run a test wash but everything should be fine the differences in the toilet is that the tanks parts are meant to constantly have water in them no like the dishwasher. But everything wares out eventually but you should be fine :)
  6. MB1
    MB1 New Member
    Apr 6, 2013
    Pennsylvania
    Thank you. It was a horrifying thought about their parts this morning, after remembering it had happened to the toilet.
    Are you a plumber?
  7. Cameron Fields
    Mar 5, 2013
    Florida
    No I am not a certified plumber nor do I claim it. I am mostly a designer and modifier I work on many projects professional, home/personal and I am really good with toilets especially American Standard Brand and Kholer Brand. I am in the process of having my own less than 1gpf (Gallons Per Flush) high efficiency toilet Manufactured. I have also designed a shower lift for the handicapped. I am glad to have helped you,
  8. jadnashua
    The smart thing for a washing machine is to turn the water off when not in use. A burst supply hose can do major damage. Not all hoses are created equal, some are better than others. Unless exposed to UV and the weather, the hoses should not have degraded much. If they are still soft and not hardened, and can flex without cracking, they should be okay. Safest is to run a load while nearby the first time. Internally, those hoses are designed for the life of the unit, but anything can happen.
  9. MB1
    MB1 New Member
    Apr 6, 2013
    Pennsylvania
    Thanks. I was worried more about the internal parts. The water has been off.
  10. hj
    The most likely problem is the shaft seal, which likes to have water around it all the time. If it is bad, the washer/dishwasher will leak when it fills with water.
  11. Wet_Boots
    Wet_Boots Sprinkler Guy
    Mar 23, 2007
    Metro NYC
    The door seal on a dishwasher might be suspect, if the dishwasher is unused long enough.
Similar Threads: Appliances
Plumbing Forum, Professional & DIY Advice Natural gas and multiple appliances Nov 4, 2014
Plumbing Forum, Professional & DIY Advice All appliances are working properly but my outside pipe is overflowing!!!! Sep 23, 2010
Plumbing Forum, Professional & DIY Advice Gas shut off valves at appliances only? May 16, 2009
Plumbing Forum, Professional & DIY Advice bad smell from gas appliances Feb 13, 2009
Plumbing Forum, Professional & DIY Advice Drip Trap for Propane Appliances Mar 3, 2007
