Anyone use an angle finder to check for 1/4" per foot slope?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by JoshRountree, Aug 30, 2011.
  1. JoshRountree
    JoshRountree Member
    Nov 3, 2009
    Fleetwood, NC
    Seems to me it would be way easier to check it with an angle finder instead of a 1" block attached to a 4 ft. level? A 1/4" block attached to a 1 foot level would work too, but the angle finder seems so easy?
  2. MASTERPLUMB777
    MASTERPLUMB777 Member
    Aug 6, 2007
    Retired Master Plumber
    Texas
    Plumbers are trained to use their torpedo levels and just crack the bubble !
    In 30 plus years have never failed a inspection yet
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Another way would be to use a line level. That is a level with hooks on each end that hook over a stout cord. Drive stakes at each end of the run and measure the distance of the run. This will tell you how much fall is needed for that section. Now stretch the cord from one stake to the next with the high end on top of the beginning point When level is located, tie the cord off and measure down the stake the distance you have determined is needed for the slope.
  5. mrmedic
    mrmedic Junior Member
    Mar 26, 2007
    Contractor
    Delaware
    On most torpedo levels the is a second line which is 1/4" slope.
  6. hj
    What is your definition of an "angle finder"? There are many types of "slope/pitchlevels" to give pipes the proper grade.
  7. JoshRountree
    JoshRountree Member
    Nov 3, 2009
    Fleetwood, NC
    http://www.digipas.com/DWL-280 Specs.html
    anything to put on top of a pipe to see what angle it is.
    BTW, the angle in degrees that I came up with for 1/4" per foot is 1.19348942 degrees, can anyone confirm or deny if that is right?
    You'd just plop the digital level on the pipe, look for 1.19 degrees and you're good! The only drawback is it's hard to find one with a degree of accuracy better than 0.2, I'm sure it'd be at least as accurate as a 4 foot bubble level?
  8. jadziedzic
    jadziedzic Member
    Aug 4, 2006
    New Hampshire
  9. Terry
    Aug 17, 2004
    1/4" per foot is 2.0833 percent
    .25 / 12.0
    Code books say 2%
    That looks like a nice level though.
    I'm used to using a simple level and just looking at the bubble.
    They last for years and years and don't need battery changes. But gadgets are cool too.
  10. JoshRountree
    JoshRountree Member
    Nov 3, 2009
    Fleetwood, NC
    That's what I'm looking for!!! Thanks
  11. hj
    IF you are working with plastic pipe, it is seldom "straight", so your digital level or angle finder is only going to measure the grade of a 12" section of pipe, unless you "slide" it along the ENTIRE length of the pipe. A 4' level distributes the inaccuracy over a longer distance and is thereform more accurate.
  12. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    When I designed and built my house, I calculated the slope along with all the drops I needed for turned elbows etc. working backwards from the septic field and then worked off the drawings measuring to the level structure. The torpedo level was used more for confirmation. I calibrated the torpedo level by placing it on top of the 4 foot level.
  13. hj
    In"commercial" work, I use a transit to set grades, but few homes need that accuracy.
Similar Threads: Anyone angle
Plumbing Forum, Professional & DIY Advice Does anyone recognize this shower valve? Monday at 2:19 PM
Plumbing Forum, Professional & DIY Advice Has anyone installed a hydapipe pipe unit before Mar 14, 2017
Plumbing Forum, Professional & DIY Advice Anyone know what this is??? It was up in a tree Feb 12, 2017
Plumbing Forum, Professional & DIY Advice Anyone familiar with American Standard shower components? Feb 4, 2017
Plumbing Forum, Professional & DIY Advice Anyone have experience with SumPro? Jan 22, 2017
