Anybody do Radon?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by gregs1, Sep 16, 2010.
  1. gregs1
    gregs1 New Member
    Mar 2, 2010
    electronics
    Pittsburgh PA
    Its all plumbing except for the fan. Just wondered who does this. I have a temp fan going.
    I am installing two pipes to the roof soon, one for radon and one for plumbing vent pipe.
    Up through bathroom closet from basement. My temp fan only draws maybe 20 CFM max.
    I have no reason to have a big diameter pipe as I see. Just need good suction out
    of basement slab.
  2. jimbo
    jimbo Plumber
    There are tons of resources on line. I went through quite an extensive review involving my daughters house, becasue they would get marginal readings...about 3 or 4. After repeated testing, including some expensive ones, and a 6 month test, we decided not to do any remediation for now. The long term test was under 2, and they said that did not indicate anything needed. She opens the windows a lot. We went through quite a lot of fussing, because the high readings were discovered shortly after large new granite countertops installed, but ultimately they were ruled out.
    The most important design point is that you must intercept the radon BEFORE it gets in the house. The one thing you do not want to do is ventilate a basement, or otherwise create a negative pressure in the house, which would bring in MORE radon, assuming it is ground sourced.
  4. dlarrivee
    dlarrivee New Member
    Jun 28, 2009
    Foam/Fireproofing/Acoustical
    Canada
    Where else other than the ground do you figure it would be coming from? Do you have some decaying Uranium in your pocket?
  5. Runs with bison
    Runs with bison Member
    Aug 23, 2009
    Midwest
    My understanding is that passive radon vent stacks are recommended in new construction for some areas with high average levels. The fan might not even be necessary, as passive stacks can sometimes do the trick. The advantage is that if you do have to install a fan, you already have a place for it.
    Our house tested at around 4 when be bought it, so we had the previous owner put in the radon system. The follow up test pulled the level down as expected. The unfortunate thing about having the fan is that it draws about 40 kwh a month.
  6. nhmaster3015
    nhmaster3015 Master Plumber
    Jul 30, 2008
    Teacher
    The granite state
    we run the pipe, install the fan and vent it through the roof but that's about all we do. Any testing we leave to others. A lot of contractors want us to add the install to the cost so we do
  7. jimbo
    jimbo Plumber
    Maybe, but that's a long story.
    Granite countertops are a possible source. Most granites have very low levels. There are a few specific granites which have been found to be problematic. And who knows what you might find in chinese drywall, or certain other building materials!!!!!
  8. dlarrivee
    Jun 28, 2009
    Canada
    Granite makes a nasty countertop in my opinion anyways, I guess I'm safe for now.
  9. gregs1
    gregs1 New Member
    Mar 2, 2010
    electronics
    Pittsburgh PA
    I would warn many about taking readings. When I moved in new old 50's home, I measured
    it about mid summer. 2.. something. I sad good. A year and a half later I started monitoring about May. It was about 10. Slowly drooped until mid summer less than 2. Mid Sep. 10. Late Oct.
    approaching 30. I hooked up a temporary system. It may go as high as 40 ??
    Thats like over two packs of cigs. a day. 16 = One pack.
    I am now doing the basement. Got everything going on. Need bathroom and radon system.
    All the installations show large diameter pipes, but it really depends on how
    much flow you have. I got a good fan, pulls 2 inches of water, and only draws about 70 watts.
    I will try to branch out and enter the slab at three points. I also worry about the cinderblock wall, and maybe I should suck them out too. One wall is mostly underground, but the others vary.
  10. Runs with bison
    Aug 23, 2009
    Midwest
    70 watts = 51 kwh/month.
    As to variability in the radon readings, that is not a surprise. Water saturation of the soil and such moves the value around. What is a surprise is how incredibly high your values are.
  11. gregs1
    gregs1 New Member
    Mar 2, 2010
    electronics
    Pittsburgh PA
    With current fan on its still above 4 in the winter. My yearly average is about 4. I also want to check outside ambient in the winter.
  12. Runs with bison
    Aug 23, 2009
    Midwest
    Man, that is high, definitely worth running the fan to suppress that. Makes you wonder about the fill or aggregate used in the concrete.
  13. dlarrivee
    Jun 28, 2009
    Canada
    That is an interesting point...
Similar Threads: Anybody Radon
Plumbing Forum, Professional & DIY Advice Has anybody seen one? Jul 8, 2014
Plumbing Forum, Professional & DIY Advice Have anybody seen this faucet fastener before? Jan 18, 2014
Plumbing Forum, Professional & DIY Advice did anybody greased EPDM seal of a butterfly valve Oct 27, 2013
Plumbing Forum, Professional & DIY Advice Anybody heard or has Nantucket faucet? Jun 18, 2013
Plumbing Forum, Professional & DIY Advice Anybody object to this pass/fail specification for city water delivery? Oct 28, 2010
