Any ways to silence a pressure assist tank?
Discussion in 'Toilet Forum discussions' started by Joerg, Dec 2, 2006.
  1. Joerg
    Joerg New Member
    Oct 6, 2004
    Califonia
    After the umpteenth shipment we did get an A/S Yorkville that actually worked and wasn't shattered. Wow. Anyhow, since a half year or so that means we have a guest bath again. But that pressure assist tank is really noisy. One of our dogs takes off in a panic whenever the royal flush cometh. I guess it's also embarrassing for guests when they push the lever and then "KAPOW ... VROOOOSH". Archie Bunker's toilet at 704 Houser Street (All in the Family) was nothing compared to a pressure-assist.
    Are there any tricks of the trade to quiet them down a bit?
    Regards, Joerg
  2. Cass
    Cass Plumber
    Nov 12, 2005
    Short of replacing it, none that I know of.
  4. Joerg
    Joerg New Member
    Oct 6, 2004
    Califonia
    Thanks, Cass. Looks like we have to live with it then. I don't want to go through that botched-delivery ordeal again. It was a nightmare to get one that actually worked.
    Maybe I try something with pressure reducers. At least that ought to muffle the "vrooosh" part of it.
    Regards, Joerg.
  5. Cass
    Cass Plumber
    Nov 12, 2005
    Why do you need the pressure type toilet?
  6. Terry
    Aug 17, 2004
    Most rear outlet floor mount toilets are pressure assist now.
    Briggs does make a gravity version, that uses the vacuity tank fittings.
    I know they say vacum, but it sure works like a 2" flapper gravity in practice.
  7. Joerg
    Joerg New Member
    Oct 6, 2004
    Califonia
    Thanks, Terry. Interesting, maybe I could try that other tank on it. It's not much of a problem in the hallway where the guest bath is. I remember you mentioning that your Glenwall can be heard from a few miles away as well :D
    But I'd hate to have one of these in our master bath. Getting older means having to go at night sometimes. Then, KAPOW - VROOOSH.
    Regards, Joerg.
  8. TPA
    TPA Member
    Mar 8, 2006
    Florida
    Closing the seat before flushing can help, but pressure assist toilets are noisy by the nature of their design.
  9. Scott
    Scott Flushmate
    Nov 2, 2004
    Tech Support
    Detroit, MI
    From the FAQs published on the Flushmate Website:
    It's not really an answer to your question but it does explain the noise level in a logical fashion.
  10. Joerg
    Joerg New Member
    Oct 6, 2004
    Califonia
    Thanks, Scott. I had read that one. Much of it is IMHO marketing fluff.
    "... a careful balance is established between the volume of water passing through the jet to evacuate the bowl ...". I don't see that happen. The jet wins every single time. In view of the dimensional "accuracy" I have seen I can't imagine how they want to control that.
    "Our testing has shown that while the peak noise levels generated by a pressure assist toilet may be slightly greater than with a gravity toilet, the noise level builds up and drops off faster with the pressure assist system." Yeah, right. That is not the case here. "...slightly greater ...", that almost made me roll on the floor :)
    Some day I'll try a pressure reducer in front of it. Won't stop the initial KAPOW but it should help with the VROOOSH part of the flush. But many of the ones in the hardware stores have that dreaded weep hole and I won't use those indoors. They always say they won't leak and then they do anyway.
    Regards, Joerg.
Similar Threads: ways silence
Toilet Forum discussions Does Toto make a Toilet with Washlet or is the Washlet always an add-on? Dec 2, 2016
Toilet Forum discussions Toilet cutaways... Feb 29, 2016
Toilet Forum discussions Is the toilet horn always even with the bottom edge of toilet? Jan 14, 2016
Toilet Forum discussions Toto (AquiaIII) Toilet - Screw at bottom right always coming loose - HELP ! Feb 23, 2011
Toilet Forum discussions Toto Promenade is always clogging...help! Dec 5, 2010
