Any tips on capping off angle stop
Chefwong
District of Columbia
I bought a 3/8" compression cap to go on a angle stop.
Put a libleral application on pipe tope on the threads and the cap wrenched on easily till it hit the bottomed out - end of the angle stop body.
Still leaks water - slight drip if the valve is opened.
I am capping it for this very same reason (even though the valve can be closed, if someone turns it by mistake.....I don't want any water coming out).
Any advice...
Plumber1
Florida
Take a nipple and grind an end to a thin taper and use it for a gasket maker. You will make a round rubber washer for your cap. I think you use a 3/8" nipple.
Mikey
Hansville, Washington
Or flatten, fold, and solder a piece of 3/8 copper to seal the end and put it in the compression fitting normally.
