Any suggestions to design a house so frozen pipes are less frequent?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by dereks, Jun 22, 2011.
  1. dereks
    dereks New Member
    Jul 4, 2007
    Seattle WA
    I know of a house where one side of the structure's plumbing gets frozen any time it's 20 degrees for 2 days. How to prevent this? Have plumbing in the interior and not running through outer walls?
    How about the garden hose on the outside? Maybe have a shutoff valve?
  2. jadnashua
    If the pipes are all in heated space...and the heating system doesn't fail, no frozen pipes. As to the hose bib, all you need is a properly installed frost-free hose bib. The working guts are inside heated space (a long shaft on the handle allows the actual shutoff to be way inside). Many of these only can work if you remember to remove the hose, otherwise, it can trap water instead of draining, so, water, cold = freezing. there are some that will drain regardless of whether you have a hose left on (check out www.woodfordmfg.com for some of the better ones). If pipes are on an outside wall, sealing for air leaks is critical. If there are no air leaks and the pipe is close to the interior, heated space, then it may not freeze. Bad place is say under a kitchen cabinet. With the cabinet doors closed, no air movement, it can get quite cold in there, especially if you didn't air leak seal things up well.
Similar Threads: suggestions design
Plumbing Forum, Professional & DIY Advice DIY no grout solid surface shower suggestions? Oct 30, 2016
Plumbing Forum, Professional & DIY Advice Suggestions on a Cast Iron Drain in a Concrete Slab - Basement Shower Apr 7, 2016
Plumbing Forum, Professional & DIY Advice Critique - Comments/Suggestions on Shower Valve Feb 21, 2016
Plumbing Forum, Professional & DIY Advice Any suggestions would be appreciated BAD SMELL IN HOUSE! Nov 12, 2015
Plumbing Forum, Professional & DIY Advice Suggestions for pipe too short (or too long) Jul 9, 2015
