Any risks to merging two 3/4" copper water supplies? (using T fitting)
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by CJ-8_Jim, Jan 14, 2010.
  1. CJ-8_Jim
    CJ-8_Jim New Member
    Jan 14, 2010
    Chicago Suburbs
    I’m splicing in another water filter in parallel to existing filter (to double velocity).
    Does anyone foresee any problems (performance or otherwise) with merging two ¾†copper water supplies into one using a “T†fitting?
    That is, one supply will come into the “T†from the left and the other supply will come in from the bottom.
    Thanks for your input.
    Jim
    It will roughly look like this when done:
  2. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    What are you trying to filter out? Cartridge filters are generally bad news as they harbor the growth of bacteria and must be replaced constantly. A backwashing filter is almost always more appropriate. If you need more filtration, it's time to start finding out why rather than just adding more filters.
  4. RTAPlumbing
    RTAPlumbing Plumber
    Jan 1, 2010
    lawrenceville, GA
    i don't use copper on well lines. You can do that if you want...
  5. CJ-8_Jim
    CJ-8_Jim New Member
    Jan 14, 2010
    Chicago Suburbs
    Still looking for an answer -- can anyone advise?
    Sorry you are confused -- perhaps the diagram is not clear that I'm adding a filter in parallel. As you probably know, doing so does not increase filtration, but will increase velocity (which is my goal).
    Why are you assuming the well is copper?
    The house was built in 1969. The whole house is copper except the well.
    Are you suggesting I hire a plumber like yourself to replace all the copper pipes in the house? Do you believe that is necessary? (Though it would be profitable for you.)
  6. nukeman
    nukeman Nuclear Engineer
    Nov 20, 2009
    Nuclear Engineer
    VA
    I see no problem except the the new filter will receive more flow that the current filter as there is a shorter path on both sides of the filter. To better balance, you could bring the feed between them with a tee and use an elbow for the new filter. Then do the same on the outlet side.
    With the current layout, the new filter may need to be replaced before the other filter as it will be a greater % of the flow (difference may be small, though).
  7. CJ-8_Jim
    CJ-8_Jim New Member
    Jan 14, 2010
    Chicago Suburbs
    Thanks much. I was guessing that too -- maybe I'll just T them off evenly (but that's adding more right angles which impact flow).
  8. jastori
    jastori Member
    May 2, 2008
    Illinois
    The restriction in flow due to the 3/4" T's will be negligible compared to the restriction from the filter itself. Balancing the piping on both sides is the ideal way to do it, although likely a minimal difference as well.
  9. hj
    filter
    There is almost NO advantage to piping it any differently than your original drawing. The flows will automatically balance themselves as one filter starts to accumulate more "debris" than the other.
Similar Threads: risks merging
Plumbing Forum, Professional & DIY Advice Candid discussion on gas piping risks Jun 1, 2009
Plumbing Forum, Professional & DIY Advice Emerging pathogens within premise plumbing Sep 20, 2015
Plumbing Forum, Professional & DIY Advice Horizontal Merging of Vents & Other Questions Oct 16, 2012
Plumbing Forum, Professional & DIY Advice Merging Pipes? Nov 11, 2008
