Any recommendations for a small pin hole leak a/c
Discussion in 'HVAC Heating & Cooling' started by richard8, Aug 19, 2012.
  1. richard8
    richard8 New Member
    Oct 20, 2008
    Washington
    Hello,
    I have a Rheem 5 ton residential a/c condenser unit that sits outside the house.
    This unit and all the similar ones in this neighborhood are approximately 20 years old.
    This type of a/c condenser uses standard R-22 type freon.
    This needs to be recharged after 25 - 28 months with R-22 freon.
    Has anyone used these two types of products, Do they work, and what are the disadvantages.
    1. A/C Leak Freeze® will stop leaks of refrigerant gas in HVACR air conditioning and refrigeration systems in homes and commercial buildings. A/C Leak Freeze® is inert until it mixes with the refrigerant. A/C Leak Freeze® is activated by refregerant escaping at the site of a leak — forming a chemical weld and sealing the leak.
    2. A/C EasySeal: #4050-06
    Treats 1.5 - 5 ton systems Nu-Calgon 4050-02 A/C Easy Seal Leak Sealant 2+1
    By Nu Calgon
    Thanks for your time.
  2. jimbo
    jimbo Plumber
    San Diego, CA
    Yes they work, and may buy you another season. With R22 this year retail at around $30+ per pound, and going higher, and availbility next year in question.....you may seriously consider why you would spend much money on a 20 year old, probably 8 SEER system. You would probably cut your electric bill in half with a new 13~15 SEER system, not to mention that your 5 ton unit is probably over-sized. Your system probably takes 7 pounds of R22. You can not ever replace your indoor unit, as the SEER mismatch would be very difficult to set up.
  4. DaMan
    DaMan New Member
    Apr 20, 2012
    Vancouver, Wa
    That is correct, R22 is and will become harder to find in the near future. R22 has already been banned in some countries and the existing supply is dwindling. Besides, your system is 20 years old. If your furnace is good, just replace the split system with one of those R410a split systems.
Similar Threads: recommendations small
HVAC Heating & Cooling Replacing Furnace - Need help on recommendations Feb 15, 2013
HVAC Heating & Cooling New construction - gas heating recommendations needed Sep 19, 2008
HVAC Heating & Cooling Does running two trunklines address the problem of trunkline duct being too small Nov 19, 2015
HVAC Heating & Cooling Cooling unit for a small room in the back of the house? Apr 22, 2015
HVAC Heating & Cooling A small church needs help Nov 13, 2013
