Any opinions on the Constant Pressure Systems
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by Dale Facey, Aug 10, 2011.
  1. Dale Facey
    Dale Facey New Member
    Jun 30, 2011
    Ontario, Canada
    I have a new well about 1100' from the house. The driller is suggesting a Goulds (i think) or some type of constant pressure system. Suggesting this as a 3 phase and in doing so and getting away with using #12 AWG wire size hence the $$$ savings from this over #8 AWG single phase system.
    I've heard some in this forum not in favor of constant pressure systems, I'd like to get more information on those with experience & any pros/cons.
    I still have to do the math to compare the cost differential of the single/standard pump versus constant solution but unsure if I shouldnt even question the cost and go single and bigger wire.
    thanks
  2. Texas Wellman
    Texas Wellman In the Trades
    Feb 9, 2010
    Owner of a Water Well and Pump Repair Business
    SE Texas-Coastal
    Wait a minute, I'll grab some popcorn.
  4. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    “Lets all go to the lobby and get some treats for the show.” Ron knows this is one of my favorite subjects.
    In the last few days I have talked to several homeowners who were talked into the VFD type system with three phase motor for cost savings on smaller wire a few short years ago. After replacing the expensive controller several times and breaking shafts and other problems with the pump itself, they are now wishing they had gone the other way. The #12 wire is cheaper if you don’t have to throw it in the scrap pile and replace it with #8 later to get a system that will actually last a while.
    Funny thing about using a VFD system in a deep well so you can use smaller wire, is that the longer the wire from the VFD controller, the worse the reflective wave and voltage spikes are on the motor. The longer the wire with a VFD system, the more problems you have.
    Pump and motor manufacturers are really pushing these variable speed pump systems because they make a lot of money continually replacing them. The more those manufacturers make, the more it cost you. Do yourself a favor and spring for the larger wire so you can have a dependable type normal pump system.
    The newest problem with VFD type pump systems is the harmonics it produces and sends back into the electrical grid. The harmonics are erasing data from radio-controlled devices like smart electric and water meters. Electric companies like Idaho Power and PP&E are now requiring homeowners to meet IEEE19 requirements. This means installing a $3500 harmonics filter and getting a $1200 certified test to be able to use a VFD type pump system. If this is not required in your area, it soon will be. That alone makes the #8 wire seem way less expensive.
    These kinds of regulations always happen on the west coast first, and within a few years everybody else will see them as well.
  5. ballvalve
    Dec 28, 2009
    northfork, california
    I have the very nice quality Goulds 1.5 hp 3 phase 4 stage [?] pump from one of these CP systems, new from an auction. [above ground booster type]
    But the controller is several hundred dollars. I am going to use this very nice pump as a booster unit with a pressure tank.
    The local mechanical supplier sells them like snake oil that cures even cancer. I dont trust the electronics - yet.
    BUT - 14 gauge wire will run most 1.5 HP 3 phase motors on a very long run, even 16 gauge in shorter ones.
    And if we get into 480 volts, you can go miles. Americans are afraid of voltage, its a big boost to the copper mines.
  6. mpt1123
    mpt1123 New Member
    Aug 12, 2011
    Mount Airy, MD
    My well is about 300' and the pump is about 18 years old. I had the bladder tank replaced about 15 years ago. Over the last year or so the water pressure seems low. I checked the bladder and it's about 1/3 filled with water. Instead of replacing it, a
    plumber I know suggested replacing the pump and bladder with a constant pressure system. Not sure of the manufacturer, but he says I could get it for cost - about $1,000.
    I'm interested in any opinion on whether I should replace the whole system with what I have or move on to the CP system.
    Thanks.
  7. masterpumpman
    masterpumpman New Member
    Mar 26, 2007
    Consult and Teach Well Drilling Internationally
    Virginia Beach, VA
    Forget the constant pressure systems, they are are a computer operated pump which are troublesome and a nightmare. I suggest that you stick with a conventional pump and #8 wire (if that is what's specified) and then install a Cycle Stop Valve http://www.cyclestopvalves.com/index2.html. If you are considering installing a new tank I'd recommend that you install a Pside-Kick http://www.cyclestopvalves.com/pdf/psidekick-brochure.pdf. The Pside-Kick comes with a small WX102 tank which is all that you need when using a CSV Valve and it also comes with the CSV valve. A CSV will give you constant pressure like city pressure.
Similar Threads: opinions Constant
Pumps and Tanks Well Forum & Blog. Water is life. standard vs constant pressure pump opinions please Jul 10, 2009
Pumps and Tanks Well Forum & Blog. Water is life. Major plumbing make over need opinions Jan 28, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Collapsed Well Need Opinions Feb 5, 2015
Pumps and Tanks Well Forum & Blog. Water is life. 3X question, any opinions or help greatly appreciated Feb 1, 2012
Pumps and Tanks Well Forum & Blog. Water is life. Opinions on Grundfos 10S05-9 to replace a Goulds 10GS05 Aug 9, 2011
