Any issue using Type B vent pipe from water heater back to chimney?
Discussion in 'Water Heater Forum, Tanks' started by vtxdude, Dec 17, 2009.
  1. vtxdude
    vtxdude New Member
    Nov 28, 2009
    NH
    Is there any issue using Type B ventpipe as far as drafting or venting? Will it draft as well as single wall? Reason is my run to the chimney runs real close to combustibles...they will be replacing the single wall that is coated with adhesive from foil tape and also the fire caulking...we are trying to rule out that is what is causing the smells after the heater has been running for about 5 minutes
    If smell is still there the Kenmore is coming out and a Bradford White is going in as that means the smell is the water heater producing it
    So Type B ok to use?
  2. zl700
    zl700 DIY Senior Member
    Aug 26, 2009
    Western NY
    Nothing wrong at all. The hotter you keep the flue gasses the better. Where I used to live it was code to use b-vent as the vent connectors.
  4. Dana
    Dana In the trades
    Jan 14, 2009
    01609
    What zl700 said- B-vent will draft BETTER than single-wall, since the exhaust gases will be hotter, less dense, more buoyant.
  5. vtxdude
    vtxdude New Member
    Nov 28, 2009
    NH
    Ok thanks guys that is good news :)
    Thanks, that makes me feel quite a bit better
  6. hj
    heater
    And if you STILL have the smell after you install the BW, what then? It means that you never found the source of the smell in the first place, and spent a lot of time and money needlessly. I doubt that it is the smell from the tape, although that flue should have been class "B" because of the proximity to the combustible wood surfaces.
  7. vtxdude
    vtxdude New Member
    Nov 28, 2009
    NH
    Well the smell is suspiciously close to the smell of the adhesive of the tape....and these pipe were loaded with it but yes I can't be sure that is it.........if it isn't from the adhesive on the pipes it has to be the water heater not working correctly? The "smell" floats up the stairwell to the cellar door and is up high near the ceiling.... Would a lazy flame indicated improper combustion? If not enough secondary air would that produce a combustion smell? The design of the BW air intake system appears to be superior to the crap design on the Kenmore?
    Yes the B pipe will be a welcome improvement..I will still wrap the pipe in the 3m Fire blanket near the combustibles for extra protection
    The one thing that changed in the basement was the water heater...no combustion smells , no adhesive smells...nothing that I can recall...could it be because of a lesser BTU rating? If the new WH is 40000 btu and the 20 year old Vanguard was lets say 32000 btu would that have any effect on the venting??
    I'm not trying to argue or dispute ...just trying to figure it all out...like I said, old water heater no smells or issue..new Kenmore goes in and all hell breaks loose......very odd
    Do any of my questions make sense?
  8. hj
    heater
    Smaller btu input WOULD require less drafting, by definition, but as I stated previously, I would want to be there to check the heater, AND smell the odor, because what you smell may not always be what you think it is.
  9. vtxdude
    vtxdude New Member
    Nov 28, 2009
    NH
    Ok hmm wondering if having the 40000 btu is contributing to the issue hmmmmmmmm Should a competent plumber be able to tell what smell is and if it is combustion smell?
    I sure does smell like a plastic adhesive smell...I guess once the new vent pipes are in that will rule one thing out I guess if it still smells
    I wonder if I should look into a GE lesser BTU water heater
  10. vtxdude
    vtxdude New Member
    Nov 28, 2009
    NH
    Ok did some more reading and I'm guess my 20 year old Vanguard was not a 40000 btu water heater.....
    So that being said.....could it be that a 40000 btu water heater could be part of the issue here? Would 4000 btu's (36000 vs 40000 btus) make a difference as far as odors or the amount of secondary air required? Could that be why the old water heater ran ok even with the negative air pressure? I can say the flame on the water heater is not short and crisp.....it is sort of tall and a bit well lazy I guess
    Sorry I'm just trying to understand if perhaps the 40000 is too big for my cellar?
    Am I over analyzing to a fault here?
  11. vtxdude
    vtxdude New Member
    Nov 28, 2009
    NH
    Well he replaced the vent pipes..had to do single wall to start because of how close to the copper gas line the run goes.....there is maybe an inch between the copper gas line and the single wall..he called a plumber and asked and the plumber told him that as long as not touching should be fine...agree?
    In any event we did some test runs and the results look promising so far..no smell and when looking outside at the chimney we could see some white exhaust coming from the stack...is that water vapor?
    I'll know better after I run through some showers
    Big question now is do I still go for the Bradford White?
Similar Threads: issue using
Water Heater Forum, Tanks WH Regen issue? Dec 11, 2016
Water Heater Forum, Tanks Is HPWH reliability still an issue? Sep 23, 2016
Water Heater Forum, Tanks Pressure Relief Valve Issue??? Problem??? Aug 3, 2016
Water Heater Forum, Tanks Gas hwt pilot not staying lit...a few issues Jun 24, 2016
Water Heater Forum, Tanks Overheating Issue Apr 15, 2016
