Any idea how I can remove this shower pan?
ibisboy1
Illinois
This house was built in the late 70's.. Not sure how to remove. I have seen the drain types where you use a key but nothing like that here.
cid:C1DA8C33-D002-4332-A184-681D8FE3A328
ShowerDude
Showers
Minnesota
to better asses removal method its good to know whAt you plan to do after removal? are you attempting to salvage your waste outlet?
i usually remove those prefabs by sawzall. i carefully cut the riser flange ring as close to the O.D. of the waste pipe on both or three sides, then carfully pry it off.
you can first cut a circle around the drain area and remove fiberglass pan or just do it all at once.
again whats the bigger scope of future drain...?
JohnfrWhipple
BATHROOM DESIGN & BUILD
North Vancouver, BC
Looks a little like a lead shield in there.
index.php
Are you installing a new shower pan or a new shower drain and custom pan?
Make sure you block the waste line before you start banging shit around.
ibisboy1
Illinois
I used a drill to put a few holes in the pan and the took a sawmill and cut around the drain. The pan came up, but, the flange and pipe are still there. Not sure where to go from here. I just want to make the area look clean (remove the flange and cap the pipe). I will let the next owner work out what they want to do with the area. I will send some additional pics of how it looks later tonight or tomorrow. Thanks for the help so far.
