Antisiphon valves downstream of reduced pressure backflow device
Discussion in 'Irrigation / Sprinkler Forum' started by inspirascapes, Jul 9, 2007.
  1. inspirascapes
    inspirascapes New Member
    Jul 9, 2007
    Is it ok/safe/acceptable to use antisiphon valves downstream of a reduced pressure backflow device(RP device)? The reason to do this is that, with the situation I'm dealing with, the antisiphon valves are already there as the functioning valves, but are at the bottom of the slope they are servicing, and thus are improperly and illegally positioned. If they are safe to use with an RP device I would rather use them, instead of replacing them with some inline valves, which would be the normal valves to use with an RP device. So whether I replace the antisiphon valves with inline valves, I will in either case be using an RP device.
    Thank you all for your attention
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    You may get someone with more expertise that I have to answer this, but IMHO, you should be OK.
  4. GrumpyPlumber
    GrumpyPlumber Licensed Grump
    Jun 18, 2007
    Plumber, self employed
    Licensed Grump
    I second that, RPZ's only kick in when there's a surge on the outlet side...so any potential loss in pressure due to the anti-siphons shouldn't be a problem.
  5. hj
    valves
    You can have as many anti siphon devices in the line as you wish, as long as you have at least proper one.
  6. Wet_Boots
    Wet_Boots Sprinkler Guy
    Mar 23, 2007
    Metro NYC
    As long as you use the RPZ, anything downstream of it is more or less immaterial. Go nuts.
Similar Threads: Antisiphon valves
Irrigation / Sprinkler Forum basic antisiphon set up w/4-5 zones Feb 25, 2008
Irrigation / Sprinkler Forum Possible top connect 2 valves in one zone? Jun 22, 2014
Irrigation / Sprinkler Forum Freeze Tolerant ball valves Feb 18, 2014
Irrigation / Sprinkler Forum automatic sprinkler valves May 1, 2013
Irrigation / Sprinkler Forum Hunter System Winterizing. Need some help with hookup. Valves not coming up Dec 2, 2012
