Anti-siphon hose bib
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Burford, Sep 5, 2005.
  1. Burford
    Burford New Member
    Sep 5, 2005
    All my antisiphon hose bibs are leaking badly when water is turned on; water pours from the top where the green plastic cover is. I understand that there is possibly a leaky washer underneath, but I can't figure out how to get the plastic top off. (Hexagonal green plastic). Brute force, or is there a trick?
  2. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    Pop that cap off, there is a rubber O-ring that is cracked. If the whole plastic part inside is cracked, then replace it with a rebuild kit. Most times it is a rubber O-ring that has cracked and split apart; a common situation with rubber products in plumbing. Produce a manufacture's name and I can probably find you a PDF explosion of your product so that you know how to take it apart. It is like a floating check valve that prevents the reversal of flow from the hose connected to the faucet, back into the potable water system.
  4. toolaholic
    toolaholic General Contractor Carpenter
    Jul 16, 2005
    Repairing and remodeling homes
    Marin Co. Ca.
    the ones ,i,ve seen in Ca.
    are metal. sound,s better than plastic
  5. PEW
    PEW DIY Senior Member
    I have found that many times it is just debris that can be clean out.
Similar Threads: Anti-siphon hose
Plumbing Forum, Professional & DIY Advice anti-siphon hose bib aka PITA... Jun 11, 2009
Plumbing Forum, Professional & DIY Advice Woodford 17 Anti-Siphon Hose Bibb Apr 20, 2005
Plumbing Forum, Professional & DIY Advice Can a Fusan anti-siphon faucet be repaired? Sep 19, 2015
Plumbing Forum, Professional & DIY Advice Fluidmaster 400 anti-siphon not refilling properly after toilet flush Jul 14, 2015
Plumbing Forum, Professional & DIY Advice Replacing Outdoor Faucet (Frost Free Anti-Siphon) Apr 22, 2015
