Anti-Siphon hole on sump/ejector pump discharge lines
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by michael-thomas, Nov 7, 2005.
  1. michael-thomas
    michael-thomas New Member
    Nov 5, 2005
    Occasionally I encounter a hole drilled in the discharge line of an ejector or sump pump a few inches above the pump and inside the pit.
    I’ve been told that this is an ant-siphon method (similar to the hole on a water heater’s dip tube) but I’ve not been able top find this documented anywhere.
    Can someone point me to a source such as manufacturer’s installation instructions or a code reference that describes when and how this should be done?
    Thanks
    Michael Thomas
    Paragon Home Inspection, LLC
  2. Lancaster
    Lancaster New Member
    Nov 7, 2005
    Quoting from Sta-Rite sewage pump installation instructions:
    "Drill a 3/16" (5mm) hole in the discharge pipe about 1–2"
    (25-51mm) above the pump discharge connection (but below
    check valve) to prevent airlocking the pump."
  4. michael-thomas
    Nov 5, 2005
    GOOGLE turned up this:
    "The vibrations and inability to pump on occasions can almost always be attributed to pump air-lock. When a sump pumps turns off, the water in the discharge line between the pump and the check valve drains back into the sump. If the pipe between the pump and the check valve is solid, the air in the line will compress the next time the pump tries to empty the sump basin. This compressed air can prevent water from leaving the pump. A 3/16 inch vent hole in the side of the discharge pipe inside the sump solves this problem. Check to see if your discharge line inside the pit has this hole. If it does, make sure it is not clogged.
    <http://www.askthebuilder.com/195_Sump_Pumps_-_Basement_Guardians.shtml>
  5. hj
    hole
    If the pump switch malfunctions and the pump removes all the water from the pit it will draw air into its volute. Without the hole to allow the air to escape as water reenters the pit, when the pump starts it would try to pump that air out first, but since it could not do it, the water would continue to rise in the pit until it overflowed, even though the pump was running. In addition, since the motor seal is water cooled and lubricated, running without liquid through the pump would damage the seal and allow water into the motor which would burn it out and require a pump replacement.
  6. sumppumppimp
    sumppumppimp New Member
    Sep 23, 2005
    This information is in all of the Zoeller Pump installation manuals! :cool: Zoeller recommends a 3/16" hole at or near the top of the pump but below the check valve.
Similar Threads: Anti-Siphon hole
Plumbing Forum, Professional & DIY Advice Can a Fusan anti-siphon faucet be repaired? Sep 19, 2015
Plumbing Forum, Professional & DIY Advice Fluidmaster 400 anti-siphon not refilling properly after toilet flush Jul 14, 2015
Plumbing Forum, Professional & DIY Advice Replacing Outdoor Faucet (Frost Free Anti-Siphon) Apr 22, 2015
Plumbing Forum, Professional & DIY Advice Mansfield Anti-Siphon Wall Hydrant Leaking in Wall Mar 19, 2015
Plumbing Forum, Professional & DIY Advice Mansfield anti-siphon faucet Aug 7, 2011
