anti scald and not enough hot water
Tom Hoffman
Orangevale, CA
Hi: I'm a woodworker not a plumber, so hopefully someone can help me.
My shower water gets warm, but not hot enough for me. The water at all sink faucets gets much hotter than the shower. I'm thinking there must be some kind of anti scald device on the shower, but what I don't know is: do these devices behave like a "governor" to keep the temp down, even if you want it hotter? I'm not talked about a sudden hot surge.
Don't know if it matters, but my heater is a tankless Rheem.
Any suggestions on how to get the shower water hotter? (I've already tried cranking up the temp setting on the hot water heater).
Thanks,
Tom Hoffman
Orangevale, CA
If you look at the instructions for the valve, you will see a temperature stop that prevents the handle from rotating all the way to the left,
Pull the handle and adjust the limiter stop.
Jimbo
San Diego, CA
The limit stop will often be a piece that looks like a gear, and there will be arrows pointing to hotter/colder. Usually you just take the handle off, lift up that piece, and turn it a little.
Gary Swart
Yakima, WA
It may take a little trial and error to get it set just right. Kind of like sneaking up on an odd miter joint.:D
