ANSI Shear Testing Procedures:
Discussion in 'Shower & Bathtub Forum & Blog' started by johnfrwhipple, Jul 12, 2013.
  1. johnfrwhipple
    johnfrwhipple BATHROOM DESIGN & BUILD for both Canada & the US
    Jul 20, 2009
    Design Work World Wide: Bathrooms Vancouver Area
    North Vancouver, BC
    Whipple Style ANSI Shear Testing (Garage style not Lab style)
    Posts deleted by John Whipple
  2. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    Shear Test Results of ARDEX 8+9 over drywall - 24 hour Fast Track Process
  4. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    Shear Test Results of GreenSkin over drywall - 24 hour Fast Track Process
  5. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    Next Round of Testing
  6. hj
    quote; My new rig was way user friendly and my first round of tests found no product willing to hold up a single large can of water.
    Does that mean that the skyscraper in Dubais which has tile on the outside at the top, is a potential killer, like the windows in the Hancock Center were?
  7. DougB
    DougB Member
    Jun 19, 2010
    Software Developer / Engineer
    Minneapolis - Land of 10,000 taxes
    How durable is Ardex Liquid Backer Board to walk on?
    I am planning to use RPM mats and warmwire, then Ardex. However, I want to tile the walls first, I'll have to use a step ladder, etc. Should I laydown plywood scraps to protect the Ardex?
  8. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    ANSI - High Rise Shear requirements for Dubais
  9. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    Strength rating of Ardex Liquid Backer Board
  10. jadnashua
    Ardex SLC has a compressive strength of around 4,000# once cured...Now, it is pretty hard after just 24-hours, but like any concrete product, takes 28-days to achieve full strength. If your SLC pour is thick enough, you shouldn't have to worry about it. But, it's not a wear surface, so you do want to protect it from dirt, and if you drop something hard on it, you could chip it. If it cracks, you didn't prepare the subfloor properly, or your pour was too thin.
  11. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    ANSI Shear Testing - Product Showdown (Ardex 8+9 vs GreenSkin vs Kerdi DS)
  12. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    My Guesses for the Product Show Down
  13. jadnashua
    FWIW, once you've fully embedded the fleece, additional thinset thickness should be irrelevant. It could be detrimental, as it would put the tile further away from the weakest point, and bigger levers move more easier. Between the tile and the membrane, there should be at least 1/16", if I remember the spec properly. Industry standards for a fleece type membrane is 50psi minimum, Kerdi typically tests out at 75 or so in the standard test, so for 4sqin, 300#. This is after a full cure, so it's hard to say if you test before that as temperature and humidity play a factor in it.
    Typically, the fleece fails before the sheeting and in a shear test, it may be hard to tell whether it was the paper on the drywall or the membrane fleece that started to fail that allows the whole thing to come down.
  14. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
  15. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    ANSI Shear Testing - 24Hour Fast Track (Laticrete 317 H2O + 15%) Substrate DryWall
  16. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    Laticrete Thin-Sets - 254 Platinum Gray - >63.42 Pounds per square inch shear test
  17. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    Shear Testing EOTA (ETAG-022) Convert newton/millimeter² [N/mm²] <—> psi [psi]
  18. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    Kerdi / Ditra Tensile & Shear Testing Data (Ditra 0.2 N/mm2 )
  19. jadnashua
    Pull strength is only important related to the tile weight since you aren't going to be able to grab the tile and pull.
  20. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
  21. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    Shear Testing Laticrete 317 (7 day set) 254 (6 day spot set)
Similar Threads: ANSI Shear
Shower & Bathtub Forum & Blog Reviewing Schluter's Dilex BWA Expansion Strip: Skylight to Tile Transition Jan 22, 2015
Shower & Bathtub Forum & Blog Tile to Hardwood Transition: Where to join the two Nov 17, 2014
Shower & Bathtub Forum & Blog Tile to Carpet Transition - A look at the best options for your home? Mar 24, 2013
Shower & Bathtub Forum & Blog SanSiro Tub Feb 6, 2010
Shower & Bathtub Forum & Blog Corner bead on tile to drywall transition? Jun 10, 2009
