Another water hammer problem
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by tedr, Aug 17, 2012.
  1. tedr
    tedr New Member
    Oct 5, 2011
    Ontario
    My water system has been working properly for a few weeks (after solving some problems with the help of the veterans on this forum) and now I have a new problem. The pump cycles on and off rapidly about 6 or 7 times at start up but I have only noticed it when the shower is in use.
    The pump is a Mastercraft 3/4 hp. It draws water from a lake. The vertical lift from the lake to the pump is about 12 feet. The pressure tank is at the cottage about 100 ft up a 45 degree hill. The water level in the lake is very low this year, so I recently added another 25 feet of poly pipe to extend the foot valve into deeper water. The water hammer problem started after that, but I'm not sure it was at the same time. Other than that nothing else has changed. There is no additional check valve in the system.
    Any suggestions would be very much appreciated.
  2. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    The pressure switch is probably too far away from the pressure tank.
  4. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    +1
    You could add a small tank at the pump.
  5. tedr
    tedr New Member
    Oct 5, 2011
    Ontario
    So have two tanks on the system? That sounds like an easy fix.
    I wonder why the problem has just started in the last few weeks...
  6. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    Most likely and that is the root of the problem.
  7. tedr
    tedr New Member
    Oct 5, 2011
    Ontario
    Here's an update...
    I added a 2-gallon tank immediately after the pump and that solved the water hammer problem. However, the rate of flow up at the cottege was very low. When I checked the pressure in the 20-gallon tank at the cottage it showed 30 psi but there was very little water coming from the taps. Then I remembered the sediment filter in the line just after the pressure tank. It was very dirty. I had removed the cartridge and by-passed the filter last fall before winter and had left it that way. But a helpful neighbour re-installed the cartridge while helping my son prime the system in the spring. When I realized the filter was plugged I replaced the filter and the result was normal water pressure.
    Now I'm wondering if the plugged filter was causing the water hammer problem. It would explain why the problem started recently as the filter gradually became harder to push water through. Regardless I'm glad I added the small tank at the pump - I think it has improved cycle time.
    Thanks very much for the advice. Every time I ask a question I get very good help and I do appreciate the education I'm getting.
  8. valveman
    Mar 15, 2006
    Lubbock, Texas
    If the filter is after the tank, it was not the problem. The question is not why did this just start happening, but why it worked in the first place. Usually they are not working right, just nobody was there to watch when it bounced the pressure switch.
Similar Threads: Another water
Pumps and Tanks Well Forum & Blog. Water is life. Another Water Hammer Question Jul 10, 2014
Pumps and Tanks Well Forum & Blog. Water is life. OK...another Noobie question...how much water should cause the well pump to cycle Mar 25, 2013
Pumps and Tanks Well Forum & Blog. Water is life. Yet another Storage tank CSV setup Question Jan 8, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Another Dumb Newbie Question... CSV Bypass? Aug 14, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Another Low yield well solution needed Mar 20, 2016
