Another Toto Drake installation question
Discussion in 'Toilet Forum discussions' started by geepondy, Mar 15, 2007.
  1. geepondy
    geepondy New Member
    Mar 8, 2007
    Toilet is set up except for the inlet plumbing but I noticed the same thing with this one as I did at the one in the showroom where I bought it. The tank doesn't sit down quite as tight as I wonder that it should and is rather "springy" to the touch. Is this normal or should it be tightened down more?
  2. TedL
    TedL New Member
    Sep 17, 2006
    NY Capital District
    The instructions that came with my Drakes (3 of them) said to tighten until you had 3 points of contact between the tank & bowl. They were pictured in the sheet.
  4. geepondy
    geepondy New Member
    Mar 8, 2007
    Thanks Ted for the response. The instructions are now gone. In your experience when tightened down to three points of contact, does the tank wobble at all or sit flush against the bow?
  5. TedL
    TedL New Member
    Sep 17, 2006
    NY Capital District
    It's touching the bowl at three points. Flush contact.
  6. geepondy
    geepondy New Member
    Mar 8, 2007
    Ok, I was looking it over and I see what you mean. By making contact in three points, that means the middle of the front part is going to touch, preventing wobble. I didn't really pay attention at the store but I see that even if touching at three points, there are going to be gaps between the tank and bowl, looking like it will be easy for dirt to get in and hard to clean.
  7. Terry
    Aug 17, 2004
    Hard to clean between tank and bowl?
    That has always been the case with two-piece toilets where the tank bolts to the bowl.
    That's why I sell a lot of the one-piece toilets.
    You can always pressure jet between the two pieces.
    I saw a home steam cleaner on TV that looked like it was doing a good job.
  8. TedL
    TedL New Member
    Sep 17, 2006
    NY Capital District
    The raised part of the bowl where it meets the tank tends to keep stuff out. But only a one piece deals with this 100%.
  9. geepondy
    geepondy New Member
    Mar 8, 2007
    Plumber was here again today fixing a mixmatch between the vanity sink drain outlet and outlet pipe below. I brought up the subject of the wobbly tank to base problem and he exclaimed "oh, all Toto toilets are like that". After he left I thought about the touching in three points and I examined closer and the two sides of the front tank were touching the bowl but nothing in the rear which was why it was wobbly. So I tightened each bolt, I'm going to say another 3/4's of a turn and then the back of the tank touched the base as well preventing wobble. The plumber seemed pretty skillful as he had to do a lot of work to get things lined up below the vanity but he said his normal job was working for a big commercial plumbing company and they recently put 50 Toto's in a building. It makes me wonder how many of them have a wobbly tank to base problem and the people probably don't even know it's wrong.
    Anyhow I now know the experience of a Toto flush. Surely that must be the max that can be done with 1.6 gallons of water. My only slight critique is that there is less surface water area then my Kohler downstairs.
  10. TedL
    TedL New Member
    Sep 17, 2006
    NY Capital District
    Mine refill so quickly, I wonder if they aren't using less than 1.6.
Similar Threads: Another Toto
Toilet Forum discussions Do all new toilets leave "skid marks"? Our Toto does. Advice on another model? Jul 1, 2010
Toilet Forum discussions Still wigged out and have another question about the Toto Aquia II Mar 19, 2010
Toilet Forum discussions Toto Pacifica & another wall mount question Jan 13, 2008
Toilet Forum discussions Yet another Toto Drake sound Nov 17, 2006
Toilet Forum discussions Toto Ultramax, Could be happier, another option? Jun 15, 2005
