Another toilet flange question
Discussion in 'Toilet Forum discussions' started by miltf, Dec 21, 2012.
  1. miltf
    miltf New Member
    Dec 21, 2012
    Alameda, CA
    Hi,
    I have removed our old 1930's toilet and discovered that the flooring and the 4" cast iron pipe are connected by a lead sheet collar. I am thinking to install an Oatey twist and set flange and bolt it to the flooring. Is this right? How can I ensure a good seal to the pipe which does not have a smooth surface? What is best: cast iron flange, abs flange, ss covered flange?
    Any other ideas? I am reluctant to remove the lead and start over.
    Thanks,
    Milt
  2. jadnashua
    None of those are approved or reliable in this situation. If the lead is intact, a plumber can lead on a new brass or bronze flange. If it's not, then it gets much more involved - the lead needs to be removed. Then, you have the choice of using whatever material you wish, pvc, abs, cast iron, or even copper to rebuild the pipe and install a new flange. There are no friction or expansion flanges designed to work inside a lead sleeve.
  4. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
  5. miltf
    miltf New Member
    Dec 21, 2012
    Alameda, CA
    Its not easily seen, but the lead only goes down about an inch to where the iron pipe starts. I was thinking the flange extensions would fit against the iron.
  6. wptski
    wptski Retired Machine Repairman
    Oct 20, 2012
    Warren, MI
    If that's lead which is soft, where is/were the closet bolts that hold the toilet down? Or was something else used back then?
  7. johnjh2o1
    Aug 9, 2009
    Retired
    Florida
    Many didn't use flanges they used closet screws that fastened the toilet to the floor. Not a good idea.
    John
  8. jadnashua
    SOmetimes, they'd lead a brass flange to the lead after it was wrapped over it (the lead, that is).
  9. johnjh2o1
    Aug 9, 2009
    Retired
    Florida
    The lead was soldered to the brass flange.
    John
Similar Threads: Another toilet
Toilet Forum discussions Another toilet flange question Oct 17, 2012
Toilet Forum discussions Another post about shallow-depth toilets Oct 2, 2012
Toilet Forum discussions Do all new toilets leave "skid marks"? Our Toto does. Advice on another model? Jul 1, 2010
Toilet Forum discussions Yet another Toilet Flange / Wax Seal Question Jan 18, 2010
Toilet Forum discussions yet another toilet recommendation Jul 22, 2009
