Well, I'll try and summarize this the best I can. Bought the house Oct. 2014. House was built in the 60's, but had some known issues, and some unknown issues. whole area is shale and has very high amounts of H2S in water, which we knew.When we did the home inspection the well was tested at spigot and was 2.5gpm. water system was also set to 40psi, which drove me nuts Maintenance basically stopped on house about 15 years ago, but that's old news.
We replaced the broken hot water heater (only one element, about 10gallons of hot water) with a newer, more efficient 80 gallon electric hot water heater. Also set house pressure to 60psi at that time. We wound up getting an air injection water filter (after my sticker shock) and everything was fine for about a month. Then the smell started back up. We discovered that we needed to replace the galvanized well tank as the filtration system wasn't getting enough water for it's backflush (approx 65gallons from company) which happens every 3 days. Also worth mentioning that pump will kick on even when flushing a 1.2gpf toilet
I recently sat through a backflush cycle and the pump will turn on almost instantly, and sometimes it starts to sound like it's cavitating, so I know there isn't the volume I need. I've consulted 5-6 different companies in 3 trades and like most people have found, have tried to either take advantage of my situation by selling me expensive things or try and baffle me with BS.
So here's my solution, I picked up a flex lite FLU-120 storage tank ( I know it's not ideal, I bought under assumption it was a bladder tank, which it isn't), and a utilitech 36 gallon pressure tank for the system. my goal is to set the well pump to fill the 120 gallon storage tank, and then install a new pump inline with the pressure tank house-side. my question is what controllers/pumps/etc do I need to complete my system. I was trying to find a float switch but I doubt any will fit inside the top fitting of my flex lite tank (1 1/4 opening on top)
Thanks in advance, I hope I didn't confuse anyone. If I need to clarify things more, let me know or if I'm thinking about this the wrong way
