thunderhead
I have read several of the threads on leveling a tub. I have a steel tub that the finish is worn and rusty. I was going to use the Rustoleum kit to paint it but am thinking I may now go with a fiberglass tub. I may still use the steel if I can get positive feedback on the Rustoleum. It would be easier than moving tubs up and down to the second floor. I read a lot about putting a mortar base under to keep it from braking and to level it. I see the new tub advertising a sump pad that goes underneath, does this replace the mortar bed?
Now for the leveling part. My tub is about 3/8" out of level, running away from the drain. Once I put the stringer up level there will be a 3/8" gap at one end. What can I do about this? First I will have to address the structural part, can't have it hanging there with a 3/8 gap. If someone sits on the edge it will probably brake or crack. The next thing is the cosmetic factor. My floor is going to be vinyl, only .125 thick so it won't cover a 3/8 gap. Any help appreciated.
