Another gurgle scenario
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by wuptdo, Apr 20, 2009.
  1. wuptdo
    wuptdo New Member
    Apr 20, 2009
    Experts,
    I've done a bunch of searching and reading. My conclusion is plumbing installations are as unique as people. I too have a gurgle. Shower/tub gurgles only when the 1st flr sink is used. Now, I must say I have an old house that I bet was never vented properly in the first place. I've attached a picture.
    Some notes:
    "white" pvc is 2"
    "off color" PVC is 1.5"
    waste is 4" cast iron to septic
    I tried to trace the current vent pipe but not sure if it's clear. It offshoots from the cast iron in basement, out the house sill? and 3/4 up the side of the house. There is no vent for the 1st flr sink which appears to be the source of the shower/tub gurgle. Any ideas? I know it's a mess. An AAV on the 1st floor sink?
    Live in NH.
  2. kingsotall
    kingsotall Plunger/TurdPuncher
    Aug 17, 2008
    Hand copper part cleaned ready to go
    Flagstaff, AZ Sitting on an upside down 5 gallon b
    That's a busy picture... :rolleyes:
    Washer machine trap must get siphoned every time it drains. Hard to tell what else is going on. Text in pic is too small to read. Can we bother you for more pics from differnet angles¿
  4. hj
    drain
    That system was assembled by someone who had heard, and believed, that anyone can do plumbing, and who needs codes and inspections. Above the tub trap there is a tee. Where do the two pipes, at the tee, go? I assume one of them is the actual tub/shower drain but what is the other one, probably the vertical one.
  5. wuptdo
    wuptdo New Member
    Apr 20, 2009
    More images...
    Here are some other angles. I'll modify the first image with bigger text tonight. Hope this helps. And yes! I forgot. The washing machine discharge overflows!
  6. wuptdo
    wuptdo New Member
    Apr 20, 2009
    I concede this. Hopefully the new images help.
  7. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Get that washer line overflowing then take off the cleanout plug at the end of the cast iron and see if the pipe is clogged and holding water.
  8. wuptdo
    wuptdo New Member
    Apr 20, 2009
    bigger text...
    ...more legible.
  9. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    No disrespect intended, but I'm not sure if you understand yet. What you have is not even worthy of being called plumbing.
    I'm quite sure any competent plumber would start by cutting out everything there and re-piping all of it.
    It's really what needs to be done.
  10. kingsotall
    Aug 17, 2008
    In short, yes, an air admittance valve on the first floor sink. :confused:
  11. wuptdo
    wuptdo New Member
    Apr 20, 2009
    OK, thanks!
  12. Redwood
    Dec 15, 2007
    Service Plumber
    It would probably be a good idea to enter these pictures in the "Pig Slop Plumbing Contest."
    Entering the contest makes you eligable to win a $25 Gift Certificate to White Castle.
    2009 Pig Slop Plumbing Contest
Similar Threads: Another gurgle
Plumbing Forum, Professional & DIY Advice another gurgle question Oct 24, 2005
Plumbing Forum, Professional & DIY Advice Same lady from ballcock with yet another question.... Nov 30, 2016
Plumbing Forum, Professional & DIY Advice Another Tee or Wye Question Oct 14, 2016
Plumbing Forum, Professional & DIY Advice Moving kitchen sink to another location. Jul 28, 2016
Plumbing Forum, Professional & DIY Advice Here is another problem that occured which I thought was interesting.... Jun 8, 2016
