Another ceiling fan problem
Discussion in 'Electrical Forum discussion & Blog' started by rburt5, Jul 10, 2007.
  1. rburt5
    rburt5 Member
    Jan 16, 2006
    Canton, Ohio
    I recently bought a house with a remote control operated ceiling fan. Everything on the remote works fine. However, the fan is also tied into the light switch on the wall. The light switch will only turn the fan (and light) off. It won't turn it back on. Is there a simple wiring mix up, or do I need a different type wall switch?
    Also, if I leave the wall switch in the on position and use the remote control to turn off the fan, it doesn't turn all the way off. It continues to hum and turn the blades very, very slowly.
  2. SteveW
    SteveW DIY Senior Member
    Feb 11, 2005
    Omaha, NE
    Any chance you are using a dimmer switch as your wall switcy? I tried that with a remote-controlled fan and some of the fan's features did not work until I swapped in a standard wall switch.
  4. rburt5
    rburt5 Member
    Jan 16, 2006
    Canton, Ohio
    It has a standard wall switch. However, the remote control has a dimmer built into it.
  5. jadnashua
    Sounds like the control board may be bad. I'd call the tech support people at the manufacturer to discuss with them.
  6. rburt5
    rburt5 Member
    Jan 16, 2006
    Canton, Ohio
    I called the technical support people and they said that my model of fan cannot be controlled by the wall switch. He said to hang the remote control beside the light switch. I'm just going to buy a new fan. Thanks for your help.
  7. Rancher
    Rancher Guest
    Thats a true statement, however that doesn't answer the question on why the remote doesn't turn the fan all the way off. Buy a different brand next time.
    Rancher
Similar Threads: Another ceiling
Electrical Forum discussion & Blog Another long electrical run Nov 19, 2016
Electrical Forum discussion & Blog Another question: generator power necessary for 1/2 hp pump jet pump Oct 8, 2016
Electrical Forum discussion & Blog Yet Another Garage Subpanel DIscussion Jun 20, 2014
Electrical Forum discussion & Blog help with another miller big 40 Mr.Rich B Jan 31, 2012
Electrical Forum discussion & Blog 3-way switch feeds another switch? Aug 22, 2011
