Anode rod replacement in water heater
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by lotuseclat79, Jul 9, 2005.
  1. lotuseclat79
    lotuseclat79 New Member
    Jul 8, 2005
    In Feb 1997, I heard a new noise in the house from my kitchen that was coming from the basement. You guessed it, my water heater blew its top. I had it replaced with the same kind - a Ruudglas Master gas water heater, Model M40S-2.
    The previous water heater lasted about 11 years with a 5 year warranty, but this time I requested a 10 year warranty. The town water folks told me that they are essentially the same - i.e. no difference.
    So, since this water heater is now 8+ years old, and drained yearly, is it too late to get a new anode rod to extend its life? What interval replacement schedule for the anode rod can extend the life of the water heater, and for how long is it good for?
    -- Tom
  2. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    Anode Rod
    you are probably wasteing your time...
    It can nearly be impossible to get an anode rod
    out of a heater that old.......
    it usually takes a heavy duty socket and a cheater bar
    also its good to have someone holding the heater in
    place to make sure you doesent move under the strain...
    but if you are lucky and can get it out,
    just the banging on that nut and effort you make
    to wrench that old nut out probably will do more damage than good
    to the 8 year old glass lineing
    The rod helps extend the life out to a certain length, 6-10 years
    depending how big a rod was installed in the unit...
    but
    after 10 years its all a guestimation how long the unit will last.
    leave sleeping dogs lie.
Similar Threads: Anode replacement
Plumbing Forum, Professional & DIY Advice W/H tank longevity and anode rod replacement? May 17, 2008
Plumbing Forum, Professional & DIY Advice Smelly hot water even after new anode rod Feb 13, 2017
Plumbing Forum, Professional & DIY Advice Replace HW heater anode rod ... Bradford White combination outlet/rod Jan 19, 2016
Plumbing Forum, Professional & DIY Advice Water heater anodes. Aug 24, 2015
Plumbing Forum, Professional & DIY Advice Powered Anodes??? Dec 6, 2014
