Anode Question
Discussion in 'Water Heater Forum, Tanks' started by xerodoc, Oct 5, 2011.
  1. xerodoc
    xerodoc New Member
    Nov 26, 2005
    Hi
    I have a Rheem 50 Gal gas water heater that is now 12 years old. It has a 12 year warranty. I have NO problem with its performance but I would like to pull out and change the Anode. This has never been done before on this unit. The water is not hard in my area. I live on Long Island in New York and use the county's water supply. My question is :am I looking for trouble by trying to remove the old Anode? i.e stripping threads etc? again the unit is working perfectly..
    I know I will need a flexible anode to replace the old one in there because of the lack of room above the heater.
    Thank you all! :eek:
  2. SteveW
    SteveW DIY Senior Member
    Feb 11, 2005
    Omaha, NE
    If the anode hasn't ever been removed in 12 years, you may not be able to easily remove it.
    I am betting that most of the pros on this site will tell you not to bother trying to patch up a 12-year-old WH.
    A good reference site is waterheaterrescue.com .
    The site owner has some tips for keeping a new WH going for a LONG time. It involves regular inspections of the anode. He does sell replacement anodes on the site as well.
  4. ballvalve
    Dec 28, 2009
    northfork, california
  5. jadnashua
    In theory, if you always maintain enough sacrificial anode surface area, the gas valve and controls will die before the tank does (well, the heat exchanger may die, too)...IOW, it should last a very long time. But, if you let the rods get used up, all bets are off. What the soft water does for you is help prevent or limit the mineral deposition (crud buildup) on the bottom of the tank that decreases the volume available and its ability to transfer heat. Theory and practice don't always coincide. If you don't use an impact wrench, you'll probably not ever get them out. Also, you may stress the gas connection and water connections while trying to twist that devil out when you apply the huge lever required to break it loose.
Similar Threads: Anode Question
Water Heater Forum, Tanks Anode rod question Sep 3, 2015
Water Heater Forum, Tanks replaced anode (picture) and some questions Aug 23, 2014
Water Heater Forum, Tanks Anode Rod Aluminum broken in two; can't get rod out of tank! Feb 11, 2017
Water Heater Forum, Tanks Anode rod under hot outlet? Ao Smith GVR 50 300 Nov 1, 2016
Water Heater Forum, Tanks Preventive Maint & Anode aftermarket or OEM only? Oct 18, 2016
