Angle stop valves for bathroom sink
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by bjferri, Mar 20, 2008.
  1. bjferri
    bjferri DoD Army
    Jun 5, 2007
    Department of the Army Civilian (DAC)
    Maryland
    The connection from the 1/2" copper water supplies to the angle stop valves, is Compression or IPT fitting better? I just want the one that is less likely to leak down the road. Thanks...
  2. jadnashua
    Properly installed, either is fine. If the compression is overtightened, installing a new one later might mean cutting the pipe back. You may need a puller to get the old ferrule off, but can reuse it - the nut might be pretty anymore, though.
  4. Ian Gills
    Jul 24, 2007
    USA
    I have both and I prefer IPT for ease of fitting and removal, and less potential to leak. And if it does leak, at least you can apply (more) teflon tape and tighten it. Not so with compressions.
    Although I did manage to tighten a compression to stop it weeping recently. Guess I got lucky and just hadn't tightened it enough when I first fitted it.
  5. RioHyde
    RioHyde Plumber
    Sep 24, 2004
    Cincinnati, Ohio
  6. bjferri
    bjferri DoD Army
    Jun 5, 2007
    Maryland
    What's the trick with getting both risers from the IPT angle stop valves pointing strait up? Is it possible?
  7. hj
    trick
    There is no trick. You just tighten them further, assuming you have not already bottomed the pipe in the valve.
  8. Mikey
    Nov 8, 2005
    Consumer
    Northern Washington
    Is it necessary?
  9. jadnashua
    Asthetically...yes. Practially, no.
  10. Mikey
    Nov 8, 2005
    Consumer
    Northern Washington
    With all the junk my wife piles under the sink, you can't see them.
    There's a good argument for compression fittings, BTW -- I put them on loosely, see how the risers want to lie, and then tighten up the compression nuts. In some cases, I'm best off pointing the stops down, rather than up.
  11. bjferri
    bjferri DoD Army
    Jun 5, 2007
    Maryland
    Asthetically I want them pointing up. I have a decorative wall hung sink w/ exposed plumbing that hits you in the face when sitting on toilet. Maybe this is a good argument for compression; would rather have IPS though...
  12. rudytheplbr
    rudytheplbr 36 Journeyman Plbr
    Sep 29, 2006
    New ****, remodel ****, repair plblg
    Ketchikan, Alaska
    Did you Know
    Did you no that there is a new style fixture shut-off valve. Its copper tube sized and you just push it on to the 1/2" supply tube. Looks neat and I beleive it's Talon that makes them.
    Good Luck,:):)
  13. jadnashua
Similar Threads: Angle stop
Plumbing Forum, Professional & DIY Advice 3/8 or 1/2 supply angle stops... what do you use? Jan 9, 2017
Plumbing Forum, Professional & DIY Advice Angle stops for pedestal sink (FIP vs compression) Aug 9, 2016
Plumbing Forum, Professional & DIY Advice Replace the Angle Stop and Supply Line, galvanized pipe nipple Jul 28, 2016
Plumbing Forum, Professional & DIY Advice Luke warm water from a hot water angle stop for a faucet Dec 30, 2015
Plumbing Forum, Professional & DIY Advice Quarter-turn Angle Stop - ID? Aug 5, 2014
