Anchoring a gas line
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by jadnashua, May 22, 2005.
  1. jadnashua
    I've got a new gas line run up to my deck for a barbeque grill. The pipe rises about 2' above the deck and is 2" from the wall. I need/want to anchor the top of this pipe, but have been debating the best method to do it. I've thought about a galvanized cast pipe hanger, or a board and clamp but neither one seems great (the siding is vertical shiplap that I can screw something to). I want the inspector to be happy, and to make it strong. There was too much going on in the wall to run it up through there.
    I could put in a shorter pipe, but I was thinking it would be so much easier to reach the shutoff if it was up a ways and would keep the shutoff out of the snow in the winter. What would you do in this instance?
  2. RioHyde
    RioHyde Plumber
    Sep 24, 2004
    Cincinnati, Ohio
    I'm sure other folks will have different ideas, but I'd use a "sammy" anchor into the wood, a short piece of 3/8" all thread rod, 3/8" nuts and a split ring hanger. After the inspection I'd paint it all to prevent rust. Provides a rigid support for the pipe.
    Good luck
Similar Threads: Anchoring line
Plumbing Forum, Professional & DIY Advice Can't remove strange closet flange anchoring screws, help! Oct 14, 2014
Plumbing Forum, Professional & DIY Advice Wall hung sink anchoring Feb 3, 2007
Plumbing Forum, Professional & DIY Advice Anchoring Copper Water Pipes Aug 13, 2006
Plumbing Forum, Professional & DIY Advice sink supply lines roughed in wrong spot Tuesday at 1:16 PM
Plumbing Forum, Professional & DIY Advice Our seemingly never ending sewer line under the house problem Feb 14, 2017
