An easy question.
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by nola000, Jun 26, 2012.
  1. nola000
    nola000 New Member
    Sep 25, 2009
    Southeast Louisiana
    Didnt get any answers on my last post so I thought I would simplify the image and query.
    Are 3" wyes acceptable in this situation?
  2. Terry
    Aug 17, 2004
    The fittings below can be 3"
  4. hj
    They can be 3" but they have to be the correct 3" fittings.
  5. nola000
    nola000 New Member
    Sep 25, 2009
    Southeast Louisiana
    Yall are great.
    I was going to use a 3x3x3x2 left side outlet sanitary tee, a street 45 and then a wye with a cleanout.
    Does that sound right?
  6. hj
    A combination Y-1/8 bend will do the same thing and eliminate a joint in the process.
  7. nola000
    nola000 New Member
    Sep 25, 2009
    Southeast Louisiana
    hj - would a "wye-1/8th(combination)" with the "left-out-sant-tee" on top be taller, shorter or the same height overall vs. a "wye + 45" with a "left-out-sant-tee" on top? Im having clearance issues so I need something that is really compact in height. Part of the reason I dont want to use 4" fittings.
    Also, in general, is there any difference in performance between a "wye-1/8th(combination)" vs. a "wye + 45"?
    I would think a "wye + 45" is better since there is a longer sweep which gets the waste flowing in the right direction for a longer time helping it downhill whereas a "wye-1/8th(combination)" would be more likely to "plop" it down like a regular sanitary tee in that configuration. Is this correct logic?
Similar Threads: easy question
Plumbing Forum, Professional & DIY Advice go easy, it's my first posting...bathroom remodel question... Jan 3, 2016
Plumbing Forum, Professional & DIY Advice Easy question (?) Jun 17, 2009
Plumbing Forum, Professional & DIY Advice Easy sink drain question Sep 4, 2008
Plumbing Forum, Professional & DIY Advice Easy question about T fitting for Pex! Dec 26, 2007
Plumbing Forum, Professional & DIY Advice 3 easy questions! Sep 17, 2007
