American standard wall hung 4040 tank/white
Discussion in 'Toilet Forum discussions' started by corycov, Apr 22, 2010.
  1. corycov
    corycov New Member
    Apr 22, 2010
    california
    Mine has a crack and needs to be replaced to sell my house. I also have two other that needs new seats. All three are original to the house from 1967. the colors are white, blue, and beige. Any help on where to get parts would be appreciated. Another option is to find a replacement but I'm not sure about the bolt pattern lining up. Thanks
    [​IMG]
  2. Terry
    Aug 17, 2004
  4. TJanak
    TJanak Member
    Sep 9, 2009
    South TX
    I have a pink tank and a green tank if you are interested. I also have the bowls, but they are both cracked at the waste flange.
    I think Terry meant Glenwall for a replacement toilet. We bought two this past year at a price of over $500 each and they work good other than being a bit loud.
  5. corycov
    corycov New Member
    Apr 22, 2010
    california
    4040 tank
    Thanks for the tips. Is the Glenwall a perfect match for my old AS or do I need some sort of adaptor?
    Thanks
  6. Terry
    Aug 17, 2004
    It's the same bolt pattern, you have to check the threaded rod coming from the carrier to see if they are adjusted out to the right length.
    You can normally loosen the nut and spin them in or out.
    Remember to save all the acorn nuts, washer and backing nuts.
    The bowl should be out from the wall about the width of a flat washer. The bowl doesn't touch the wall, it snugged up against the backing washers and nuts.
    You can only tighten three nuts, the fourth is hand snugged. If you wrench tighten the fourth nut, you will be buying a new bowl.
Similar Threads: American standard
Toilet Forum discussions 24 Unit Toilet Purchase - Need Some Input (Toto/American Standard/Duravit/Caroma/Stealth) Feb 9, 2017
Toilet Forum discussions American Standard Champion 4 Mystery Part Jan 5, 2017
Toilet Forum discussions Best American Standard 12" Toilet for 11" Rough In Jan 2, 2017
Toilet Forum discussions American Standard DXV Lyndon Nov 21, 2016
Toilet Forum discussions Standard (non-ADA) height toilet - Toto Eco Drake, American Standard Cadet, other Oct 3, 2016
