American Standard Tank#4072 tank to bowl gasket
Discussion in 'Toilet Forum discussions' started by badreligion9265, Mar 28, 2013.
  1. badreligion9265
    badreligion9265 New Member
    Dec 5, 2009
    new jeresy
    As the title states I'm wondering if the tank to bowl gasket inside of the fluid master complete repair kit will fit my toilet(AS TANK# 4072). Here is a link to the kit I'm referring to. American standard told me the part number for my tank to bowl gasket was 047188-0070A not sure if that helps but in case it does thought I'd provide it. Thanks.
    http://www.fluidmaster.com/our-prod...et-parts/complete-toilet-tank-repair-kit.html
  2. wptski
    wptski Retired Machine Repairman
    Oct 20, 2012
    Warren, MI
    I don't remember my tank part number right now but it's a Cadet 3 1.6gpf 10" rough in which had a leaky tank right out of the box. I bought the FM 3" flush valve just in case the replacement tank leaked also. I used the flush valve gasket from the kit. I can tell you that the FM sponge gasket under the tank wasn't the same height. IIRC correctly it's taller and I used the OEM. I have it and can measure it if you care to know.
  4. bbecker56
    bbecker56 New Member
    Jun 14, 2013
    Philadelphia
    I have an American Standard 4014 Cadet. I can see that the ace gasket is too tall because the tank won't sit right on the base. Consequently, it leaks. (excuse my novice vocabulary.) Can I use the fluidmaster thinner gasket or do I need the thicker one like the Ace? The thinner gasket & washer is 3-1/4 o.d., 2-1/8 i.d., and 9/16 thick. Thanks!
  5. wjcandee
    wjcandee Wise One
    Apr 27, 2012
    New York, NY
Similar Threads: American Standard
Toilet Forum discussions 24 Unit Toilet Purchase - Need Some Input (Toto/American Standard/Duravit/Caroma/Stealth) Feb 9, 2017
Toilet Forum discussions American Standard Champion 4 Mystery Part Jan 5, 2017
Toilet Forum discussions Best American Standard 12" Toilet for 11" Rough In Jan 2, 2017
Toilet Forum discussions American Standard DXV Lyndon Nov 21, 2016
Toilet Forum discussions Standard (non-ADA) height toilet - Toto Eco Drake, American Standard Cadet, other Oct 3, 2016
