American Standard diverter valve problem
Discussion in 'Shower & Bathtub Forum & Blog' started by SWEET GT, Nov 16, 2006.
  1. SWEET GT
    SWEET GT New Member
    May 1, 2006
    I am in the process of replacing my diverter vavle. I figured its a quick job..turns out isn't (at least not for me, the rookie.) :)
    Here is my issue..I can get the valve in no problem..but the valve/stem will keep turing counter clockwise, and I cant get 100% of the water to go to the spout..its about 80% to the spout and 20% still to the head.
    If I turn it clock wise, it will completely seal off the head and divert 100% to the spout..but the valve/stem will keep turning...The handle is not stripped either..I replaced those as well.
    I dont think there is anything else i need to replace..there is nothing in the pipe that I know that is part of this assembly.
    Here is the new (top) and old (bottom) valves:
    [​IMG]
    Here is the best pic I could take of the inside of the pipe..its kind of dim..but I dont see anything in there that should/needs to be replaced:
    [​IMG]
    I am desperate from help..something this simple..I have wasted hours on :)
  2. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    Is that a Danco replacement stem or a American Standard Genuine replacement stem.
    Danco is notorious for product failure right off the shelf.
  4. SWEET GT
    SWEET GT New Member
    May 1, 2006
    Its Kissler & Co and says "Keep It Simple System".
    The thing is, is i I put the old one back in, it behaves the same way..
    I figured these things would just pop right in....
  5. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    From the picture, I'm not sure why you decided to replace the blamed thing.
    I assume that the seating surface where you close off the spout has some sort of composition or plastic to seat against.
    When you put that assembly back in make sure that it is tightened real well because if not it will slip.
  6. SWEET GT
    SWEET GT New Member
    May 1, 2006
    The thing was leaking and i just bought the whole unit instead instead of replacing the O rings..figured while I have the wall/cover plate off Id replace it all at once to avoid redoing it...let me try tightening it up real good..i was trying to avoid over tightening..
    I just made sure the valve was nice and tight in the pipe and it is..the stem still wants to turn counter clockwise like there is no stop..
  7. hj
    diverter
    The "screw" is in that bottom section, and if it is not tight in the valve body once the diverter is turned out so it contacts that piece, it will just rotate. It appears to be a Heritage diverter, and it looks like all the parts are there, according to what we can see.
  8. SWEET GT
    SWEET GT New Member
    May 1, 2006
    So the silver "screw"/shaft needs to be tight in the brass barrel or else it will keep spinning is what you are saying?
    How the heck do I tighten the barrel on the screw? I cant get a good grip on it using just my hands :)
  9. hj
    diverter
    NO! The brass barrel has to be tight in the faucet body so it will not turn when the brass stem touches it. Why yours is not doing that is something we cannot tell you from here, because we would have to work on the faucet to see what is happening inside it.
  10. SWEET GT
    SWEET GT New Member
    May 1, 2006
    Gotcha..well I will see what i can do this weekend..thanks for the tips
Similar Threads: American Standard
Shower & Bathtub Forum & Blog Help identify this American Standard Valve Trim Jul 18, 2016
Shower & Bathtub Forum & Blog American Standard shower handle removal Jun 27, 2016
Shower & Bathtub Forum & Blog American Standard Aquarian Valve New Handle Feb 24, 2015
Shower & Bathtub Forum & Blog American Standard Renu Stems/Valve Hammering Dec 2, 2014
Shower & Bathtub Forum & Blog American Standard Shower 2077-302 Ceratop / sleeve replacement. Oct 23, 2014
