Beaglebuddy
The customer's son had disassembled the valve and replaced the cartridge twice but it continued to drip from the cartridge where the o rings mate up with flat surface on the valve body, a steady drip ran down the wall and dripped thru the ceiling in the kitchen below oddly only when the valve was turned on.
I replaced the cartridge with one of mine but as the drip continued I tightened the three screws until the cartridge finally cracked with a loud noise.
OK plan B, I knew that on this road the water company had sent out notices in the last year that they had increased the pressure and everyone should have a PRV installed in fact I had a Grohe kitchen faucet down the street that was leaking because of this.
The pressure was 85 PSI so I installed a PRV and guess what? At 50 PSI it still leaks just the same.
Could it be that the cartridge was damaged from the high pressure? Someone else must have had this problem. I really don't want to cut the valve out of the wall.
